VideoHelp.com Forum
    I'm not sure this is the right thread, but I have no clue where else to post. I'm trying to get an effect done in Adobe Premiere CS3 but it's not working.
    I have a clip and I want it to fade to black and white (e.g; no saturation) at a certain point near the middle of it.. and then a few seconds later fade back into colour. How do I do that?
    Also, whenever I import a movie from my camera to Sony Vegas Pro, only the sound appears in the time line, not the image.. why?
    Thanks.
    P.S: I'm using a Nikon D90 to film my videos in the highest resolution possible.
    In PP , you can use the color balance (hls) effect, the saturation part of the "hls"
    Set a keyframe for when you want it to start to fade (value=0), advance in the timeline , set a keyframe for when you want it fully desaturated (value = -100), then advance in the timeline, set a keyframe for when you want it to resaturate back to normal (value=0). You can fine tune the transitions by moving keyframes or right clicking them for interpolation options
    Use mediainfo on your file for clues as to why it won't import into vegas
  1. SxS Pro card file MXF to DVD using Adobe Premiere Pro CS3
    By Fary4u in forum Video Conversion
    Last Post: 20th Jul 2009, 09:00
  2. Adobe Premiere pro CS3 to DVD using MP4
    Last Post: 13th Jul 2009, 12:13
  3. Adobe Premiere Pro CS3 ERROR =/
    By ervand in forum Editing
    Last Post: 11th Nov 2008, 22:28
  4. Vegas Pro 8 versus Adobe Premiere CS3
    By SCDVD in forum Editing
    Last Post: 26th Feb 2008, 17:57
