VideoHelp.com Forum
  1. Former Kanenite
    Is there an easy guide out there? The only guide I've found requires several programs and doesn't say what you are supposed to do with said programs.
  2. Former Kanenite
    What if I want to keep everything? Do I need to demux and then mux every file?
  3. Member wulf109's Avatar
    I've converted many of my HD-DVD's to blueray with Ripbot. Movie only,but Ripbot will join the evo files,usually two and convert to blueray.
    I have found that RipBot264 with mkvMerge GUI (part of the mkvToolnix) (and BDSup2Sub if you want subtitles) works great and is generally fairly easy (at least as easy as converting a standard DVD.) I've written a guide, and you can find it here (bit of shameless self-promotion )
    If you start trying RipBot and have questions, feel free to PM me or drop me a line in my guide's thread. Good luck!
  1. Replies: 5
    Last Post: 13th Aug 2011, 03:35
  2. convert non blu ray movie to blu ray disc???
    By dalmar6677 in forum Authoring (Blu-ray)
    Last Post: 31st Aug 2010, 18:51
  3. Replies: 11
    Last Post: 24th Aug 2010, 19:57
  4. Opinion - easiest blu-ray player to hack region free?
    By burninglow in forum DVD & Blu-ray Players
    Last Post: 12th Jul 2010, 23:17
  5. Replies: 3
    Last Post: 12th Apr 2010, 23:07
