VideoHelp.com Forum
    In the past I have used Logoaway and Vitural Dub to remove logos, and it works.
    Hiwever, this time I need to remove a logo a point with-in the video and for a set amount of time.
    Logoaway does not seem able to do thiis. All it can do is "remove" the logo for the whole length of the video, or if I just want to save a segment.
    Is there a application that will do what I want?
    And if so, what is it??
    You can apply filters in sections with the curve editor in vdub
    Do a search as there were several posts this last week related to this topic and illustrative screenshots
  3. VDub's DeLogo filter allows you to select on which frames you want it applied:
    Now go to "video" again, choose "filters" click on Delogo (it's already applied) and where it says "on frames" we will type in the frames we want processed. In our example the logo began on frame 400 to 10000. Enter it as 400-10000, then a comma, and the next set. Our example would look like this: 400-10000,13500-22356, etc etc.
    http://forum.videohelp.com/topic280003.html#1376335
    Me, I use AviSynth's Trim command to isolate the frames on which I want to apply one of its many logo removing filters.
    Sorry for the delay in answering
    I went to the DeLogo forum page and followed it.
    It worked.
    However, there is somethings I would like to point out about the instructions.
    1, It does not mention what to do if there is no black background to your video.
    2: That DeLogo is VERY particular of the red you use. For example, when I try using any red from Corel Photo-shop I kept getting a warning it was not the "correct" red. Only when I use red from Windows built in paint program did it accept it.
    3: The forum states that you should " TURN OFF "alpha to repair" slider! All the way to zero." Well, I don't know if it was because I had a light background, but, I had to move the slider to almost it highest setting to get the logo to remove.
    4: When trying to convert and the "cleaned up" Avi video to MPEG-1 before pasting back into the rest of the original video using Dazzle's MovieStar 5 .An area corresponding to the old logo was very noticable (dark patch or blocky pattern) for the whole video. It was only when I used TMPGEnc did I not get this.
    Well, that was my experience with DeLogo. Now that I know what to (and not) do I can use it in future projects.
    Thanks for the help.
  1. LG DR787T - certain channels will not record for entire set time
    By treefrog10 in forum DVD & Blu-ray Recorders
    Last Post: 3rd Mar 2009, 07:25
  2. Replies: 6
    Last Post: 20th Feb 2009, 15:59
  3. Saw AWESOME HD recorder. No copy protection. HD out. Set top. Real time.
    By Evilmind in forum Newbie / General discussions
    Last Post: 13th Aug 2008, 18:56
  4. Clock will not stay set to correct time
    By driley in forum DVD & Blu-ray Recorders
    Last Post: 28th Mar 2008, 00:20
  5. How to set delay time of all text in the sub.
    By hmanhha in forum Subtitle
    Last Post: 22nd Feb 2008, 13:53
