Hi guys,
im trying to digitalize the old family VHS tapes using the Ion VRC2PC tool. Despite the negative comment on this forum, I am quite happy with it; for an amateur like me, it does the job fine. I do not get macrovision errors and because the quality of the source tapes is relatively good for 1985-1990 material (Maxell Epitaxial Video Casette HGX Gold). The material looks quite nice overall, yet I have however 2 problems:
1. The deinterlacing/interlacing problem (i dont know how to call this). I am quite new to this and don't know what to do with it. Should I fix this using some kind of tool, or is it better to keep it in original quality? I can't tell using the information on the forum here.
2. The source VHS tapes contain multiple scenes on one tape; for example Tape A contains the years 1984-1986. As a result, some scenes do look quite good, but others have too much light or are too dark, or do not have a good color balance (the famous in-house recording). I am wondering about what to do:
a. keep the complete tape in a 8gb mpg file and use a bunch of filters on the video as a hole, or
b. cut the file into different scenes and use customized filters per scene. This will be much more time consuming, ofcourse.
Thanks for helping me out!
1) Don't fix the interlaced lines unless you wanna make adivx or upload to youtube for instance
2) To enhance dark regions (etc..) there is a vdub filter called color mil, you should try that
3) Use virtualdub to fix the scenes that need to.
4) Record in avi / huffyuv codec for such a restoration projectTheMaster Rules ;)
VHS to DVD (basic questions)
By BPH2002 in forum Video ConversionReplies: 5Last Post: 2nd Jan 2008, 10:32 -
Advice needed submitting Vob for restauration suggestions..
By 20/20 in forum RestorationReplies: 3Last Post: 13th Apr 2007, 17:03 -
Procoder Express or CCE Basic or TmpGenc Xpress 4.0 for VHS conversion
By darkin in forum Video ConversionReplies: 9Last Post: 7th Jan 2007, 05:27 -
Basic hardware question, VCD to VHS
By Amod in forum Newbie / General discussionsReplies: 1Last Post: 19th Nov 2002, 13:38
Statistics
Newest guides
Latest tool updates
New media comments
