VideoHelp.com Forum
    I recently entered the wonderful world of HDTV when I bought a Samsung LN37B530. I then purchased a WD TV HD Media Player which was simply AMAZING! However, for some reason I can no longer connect my TV with the Media Player through an HDMI port! The TV simply says there "no signal". There are 3 HDMI ports on my TV: none will work with the WD Player. I also have 2 HDMI cables - a 6' and a 10': neither works with the WD. Both cables & all 3 ports work with my blu ray player. I did have a 4' HDMI cable which worked with the Media Player, but I traded that away. I have updated the firmware for both the TV & the WD player - no joy. The WD Player works with the RCA composite Jacks, but really, what's the point? Is there some limit on the length of HDMI cable that the WD Player will be able to accomodate? Or is it my TV?
    Thanks!!
    You may want to contact WD for support.
    ktnwin - PATIENCE
  3. Hello Ladies stiltman's Avatar
    Had the same problem
    I connected via composite
    Changed the HDMI settings to the lowest
    Reconnected the HDMI
    then the signal came through.
    Then I manually upped the quality one tick at a time.
    Originally Posted by jagabo
  4. Mod Neophyte Super Moderator redwudz's Avatar
    I had a similar problem to stiltman's and basically did the same thing. HDMI is a 'handshake' protocol and both units have to agree or it doesn't work. Check your WD/TV settings.
    I use a 45 foot HDMI cable to my projector, so cable length is likely not an issue for you. If all that fails, then maybe the WD HDMI port died.
  1. Can I connect camera HDMI to camcorder HDMI?
    By Darryl In Canada in forum Newbie / General discussions
    Last Post: 15th Jan 2012, 16:06
  2. Media Center won't download tv guide
    By Stoney Curtis in forum Computer
    Last Post: 15th Dec 2011, 15:35
  3. Media center video won't play on standalone dvd player
    By larrym in forum Newbie / General discussions
    Last Post: 7th Jun 2008, 22:04
  4. why cant you connect to a PC via HDMI/DVI?
    By nineinone in forum DVB / HDTV
    Last Post: 24th Aug 2007, 15:04
  5. Replies: 14
    Last Post: 2nd Jun 2007, 22:23
