VideoHelp.com Forum
    hi i have been trying to convert truehd to dts 1536, the source is batman begins blu ray, when i load the truehd ac3 file in eac3toGUI i set the destination file as name.dts, select dts 1536 from the drop down box and leave everything else, near the end of converting though, this is the log
    eac3to v3.16
    command line: "C:\Users\home 2\Documents\blu ray tools\eac3to316\eac3to.exe" "E:\Downloads\BATMAN_BEGINS\BDMV\STREAM\00000.trac k_4353.ac3" "E:\Downloads\BATMAN_BEGINS\BDMV\STREAM\batmandts1 .dts" -1536
    TrueHD/AC3, 5.1 channels, 48khz, dialnorm: -27dB
    (embedded: AC3, 5.1 channels, 640kbps, 48khz, dialnorm: -27dB)
    Extracting TrueHD stream...
    Removing TrueHD dialog normalization...
    Decoding with libav/ffmpeg...
    Writing WAVs...
    Creating file "E:\Downloads\BATMAN_BEGINS\BDMV\STREAM\batmandts1 .SL.wav"...
    Creating file "E:\Downloads\BATMAN_BEGINS\BDMV\STREAM\batmandts1 .R.wav"...
    Creating file "E:\Downloads\BATMAN_BEGINS\BDMV\STREAM\batmandts1 .LFE.wav"...
    Creating file "E:\Downloads\BATMAN_BEGINS\BDMV\STREAM\batmandts1 .SR.wav"...
    Creating file "E:\Downloads\BATMAN_BEGINS\BDMV\STREAM\batmandts1 .L.wav"...
    Creating file "E:\Downloads\BATMAN_BEGINS\BDMV\STREAM\batmandts1 .C.wav"...
    [libav] End of stream indicated <WARNING>
    The original audio track has a constant bit depth of 16 bits.
    Encoding DTS <1536kbps> with Surcode...
    Found Surcode DTS Encoder version 1.0.23.0.
    Surcode says/asks: "Parallel port lock required to run this program.".
    Pressing the Surcode "Encode" button didn't seem to work...
    Closing Surcode...
    after this, i try opening surcode and loads of messages pop out at me saying each wav file is an invalid wave file or something like that, after that i just close surcode
    i dont know what to do, please help
    Do you have a licensed version of surcode with the dongle plugged in?
    no
    done it now, i changed my surcode version to 1.0.21, but for some reason when i loaded the dts file in mkvmerge it did not ask me to enter the fps, like 23.976, it did last time but last time it was a different movie, and with that different movie the original sound was dtshd, but converted it to dts and when i put that in mkvmerge it asked me for fps
    but the audio and picture of batman begins looks ok, so i guess there is nothing else i need to do?
    and the other movie is also the same, that is ok
    so i guess i am all sorted and good now?
    thank you
  1. Replies: 5
    Last Post: 18th Apr 2012, 21:00
  2. How to convert AC3 True-HD to DTS ?
    By Kernell in forum Audio
    Last Post: 28th Nov 2011, 19:42
  3. How i can convert dts-es to dts-core from one mkv file?
    By fits79 in forum Video Conversion
    Last Post: 11th Jun 2011, 21:24
  4. DTS 1536 kpbs not clear with VLC
    By foaley77 in forum Audio
    Last Post: 10th Mar 2010, 20:53
  5. True HD/ DTS-MA/HD support for mkv container?
    By runLoganrun in forum Blu-ray Ripping
    Last Post: 17th Jan 2009, 09:14
