VideoHelp.com Forum
Thread: RM Joiner
  1. I need a program (preferably free) for joining two RM files.
    Any recommendation?
  2. Mod Neophyte Super Moderator redwudz's Avatar
    Real uses a highly proprietary video format and they discourage outside software development for their format, so you may not find many editing programs, free or otherwise. Besides that, a lot of RM video uses variable bitrate video and audio, which makes it really hard to join without sync problems. But you can try this freeware program: Easy RealMedia Producer & Editor
    I just convert it to a different format, then do any required editing. I use Any Video Converter Free Version to convert the format to something more usable.
  3. Thanks.
    I tried to convert RM to AVI but the resulted file is too big.
    I have managed to do the job using a program called: Boilsoft Video Joiner.
    Not free, but fast (this application join video files without re-encode)
  1. F4V Joiner
    By eaglei1982 in forum Video Conversion
    Last Post: 20th Dec 2010, 12:09
  2. AVI Joiner
    By vipertongn in forum Editing
    Last Post: 25th Oct 2010, 17:42
  3. Need an MP3 joiner
    By OM2 in forum Audio
    Last Post: 6th Apr 2010, 23:53
  4. FLV Joiner
    By Wolfin2010 in forum Editing
    Last Post: 1st Feb 2010, 11:07
  5. Converter/Joiner?
    By Steph-x in forum Editing
    Last Post: 28th Jun 2008, 10:52
