How long does it take you guys to rip/compress/burn a blu-ray? I know it varies between systems but I'm just looking for an average. Thinking of building a new PC just for faster speeds if it would be significant (Currently running an antiquated p4 2.6 OC'd to 3.1 with only 1 GB RAM). So, how long to rip a dual layer disc and compress/burn it to a single layer disc?
The only procedure that's really related to PC speed is the compression process. It takes me about five hours to convert a 25GB+ BD disc to a 7.95GB DL MKV data disc using RipBot. That's on a quad core 3.6Ghz computer. When I used a 2.5Ghz quad core, conversions took about six hours or so.
Ripping takes whatever time your BD drive takes to read the disc, 40 - 50 minutes. Burning a disc is the same, whatever your burner speed/media speed is. If you are burning directly to BDRW, just takes the ripping time and burning time if the movie will fit directly on a BD disc. ImgBurn can do that.
You also asked about DL>SL disc conversions? I use DVDShrink for that after decrypting. Shrink takes about a half hour or less, depending on the DVD source size, for the whole process.
The amount of RAM you have doesn't have much bearing on ripping, converting or burning. But I use 2GB for XP and 4GB for Vista. With these type of conversions, especially to H.264 (MKV), a fast quad core will help considerably to shorten encoding time.
blu ray burner able to write but not burn
By beezneez52 in forum DVD & Blu-ray WritersReplies: 5Last Post: 22nd Jan 2009, 22:34 -
Burn 1-5 dvd's on one blu-ray?
By Kotten-74 in forum Authoring (Blu-ray)Replies: 1Last Post: 18th May 2008, 15:45 -
Can I rip Blu Ray Discs with LG Super Multi Blu-ray Disc and HD DVD-ROM Dri
By donpato in forum Blu-ray RippingReplies: 5Last Post: 5th May 2008, 17:05 -
My Sony Blu-ray player BDP-S1 does not recognize my Blu-ray Disc
By showgirl in forum Newbie / General discussionsReplies: 5Last Post: 2nd Oct 2007, 13:48 -
First Blu-ray disc drive won’t play Blu-ray movies
By akrako1 in forum Latest Video NewsReplies: 15Last Post: 14th Aug 2006, 00:30
Statistics
Newest guides
Latest tool updates
New media comments
