VideoHelp.com Forum
Results 1 to 18 of 18
  1. Member usta's Avatar
    What is the best/most common GUI for ffmpeg encoding?
    I've tried WinFF - good presets, batch convert, multi threaded.
    What are your experiences?
  2. Member ricardouk's Avatar
    Avanti is my choice for ffmpeg...the only thing missing...automatically mux h264+aac with mp4box so it could be streamed online "out of the box"
    lots of functions and profiles
    I love it when a plan comes together!
    Ricardo Santos
  4. Member usta's Avatar
    Baldrick, ffmpeggui seems very old...
    Besides, isn't it only for audio?
  5. I'm a MEGA Super Moderator Baldrick's Avatar
    You missed my . It's my little gui that I made SEVERAL years ago.
    Nowadays I use WinFF or just the command line.
  6. Member usta's Avatar
    Aha, I see.
    I don't use a GUI, I just like having absolute contol over what ffmpeg does, especially when it comes to x264 settings.
  8. Member usta's Avatar
    If the GUI allows (like WinFF), you can type all the commands as well.
    Or you type all that in a .bat file?
  9. Member ricardouk's Avatar
    Ricardo Santos
    AutoMKV gets my vote for best GUI.
    auto dgindex, auto crop/scale is a few convenient features.
    If you know ffmpeg CLI you can tweak your own settings to create profiles.
    Cheers.
  11. Member usta's Avatar
    Thanks ricardouk!
    Can Avanti do batch conversion?
    Edit: Yes it can!
  12. Member usta's Avatar
    OK, I did some conversions using Avanti and AutoMKV.
    I've decided to keep them both, next to WinFF.
    Each of them (WinFF, Avanti, AutoMKV) has some unique features and I couldn't force myself to depart from any of them...
    It took me a while to go over all those features of AutoMKV: what a contrast to the minimalistic interface of WinFF.
    By the way, neither Avanti, nor AutoMKV require an installation on the PC.
    Offtopic: Where do they come up with such stupid names as AutoMKV (which clearly is not limited to MKV) and Xvid4PSP (which clearly is not limited to Xvid or PSP)???
    To me the name AutoMKV is quite clear of its capabitities.
    The MKV container itself can handle practically all audio/video codecs.
    Anyway, if you like automkv, you'll also like HDConvertToX they're both from the same author - HDConvertToX should give you a hint of what the app can do.
    Cheers.
  14. Member usta's Avatar
    Thanks for the suggestion: I can already see the similarities of AutoMKV and HDConvertToX. So much to try, so much to learn...
  15. Member ricardouk's Avatar
    if you want a to use mencoder like hdconverttox (i cant do anything with it) it tries to create a dummy mkv file with whatever file i try to convert.... if you wanna try mencoder use Automen from the same author.
    http://forum.doom9.org/showthread.php?t=127298
    Avanti for ffmpeg and automen for Mencoder are my suggestions... simple, portableb and a no brainer to use.
    Ricardo Santos
  16. Member usta's Avatar
    I've tried a conversion with Automen.
    The positive side is portability and clear interface!
    The negative side was less control over the codec settings directly from the GUI (I wanted to disable B-frames for xvid encoding, but I couldn't see how). In addition, even though I've selected MP4 as a container the output was in avi container???
    Anyway, for ffmpeg, I'm sticking to both WinFF and Avanti.
  17. Member ricardouk's Avatar
    the link i gave you was for the version 6 (beta) try the following links for the stable version:
    Version 5
    5.4 update
    to modify the Bframes, open the profiles text file inside automen and modify/add those parameters, you can create new ones.....
    For example:
    \XviD 1 pass Fast\ -ovc xvid -xvidencopts bitrate:max_bframes=0:vhq=0:me_quality=5:nochroma_me:nochroma_opt:nohq_ac:notrellis:nolumi_mask:autoaspect:bvhq=0
    and change/add to:
    \XviD 1 pass NoBFrames\ rest of the settings
    I use automen for flv output as i find it produces better quality than Avanti, apart from that those are 2 great programs with Avanti taking the lead on advanced functions
    Ricardo Santos
  18. Member usta's Avatar
    ricardouk, Thanks for all the valuable information. I've learned a lot in this thread!
  1. Full FFMpeg/Mencoder gui?
    By TSJNachos in forum Video Conversion
    Last Post: 16th Jun 2011, 02:24
  2. AutoFF a new gui for FFmpeg (v. 0.99.8)
    By buzzqw in forum Linux
    Last Post: 16th Aug 2010, 09:49
  3. Recommend a GUI for FFmpeg
    By David_UK in forum Video Conversion
    Last Post: 2nd Feb 2009, 07:35
  4. New (advanced) FFmpeg GUI for Windows OS builds.
    By Chris K in forum Video Conversion
    Last Post: 24th Nov 2007, 06:15
  5. My new FFmpeg GUI - Kiss DTV 2 DVD
    By slmnow in forum DVB / HDTV
    Last Post: 21st Nov 2007, 10:46
