I am trying to demux a file I have recorded from Satellite HD channel. I have used DvbviwerPro to record. The final file can not be played in most players. The video can be seen using MPHC, but without audio. I have tried ProjectX, Super, avidemux, Yamb, some video converters (include commercial ones) and no success. The problem appears to be in the audio stream. Mediainfo shows audio as AAc. It's AAC HE indeed. But most players and converters read the audio as Mpeg, so they can not play it.
I have upload a sample file.
http://www.megaupload.com/?d=9SJLY5OE
I have search google, foruns and found nothing that work.
Any help will be appreciated. I would like to demux my recordings and mux back (mkv) to see using WDTV media player, or computer.
Thanks in advance.
General
Complete name : P:\DVBVIEWER RECORD\Samplefile.ts
Format : MPEG-TS
File size : 59.1 MiB
Duration : 50s 166ms
Overall bit rate : 9 877 Kbps
Video
Menu ID : 2 (0x2)
Format : AVC
Format profile : High@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16/9
Frame rate : 29.970 fps
Resolution : 24 bits
Colorimetry : 4:2:0
Scan type : Interlaced
Scan order : Top Field First
Audio
Menu ID : 2 (0x2)
Format : AAC
Duration : 49s 834ms
Video delay : -745ms
Language : Portuguese
Thread: Demux DVB-S HD H264/AAC HE
Tried tsmuxer ?
It uses LATM/LOAS AAC audio ; not very many software can decode it properly presently
Use DGAVCIndex to demux the audio, use winamp to convert to wav, then convert the wav to something else that your media player can play (e.g. AC3 or regular AAC). For that wav=> (something else) conversion there are many options eg. megui, behappy, foobar2k, etc..
The other method is to set up a directshow filter graph using graphstudio and the medialooks aac decoder (monogram), then use avisynth and directshowsource() with .avs scripts to convert
Then mux back into .m2ts using tsmuxer , or mkv using mkvtoolnix (although .mkv overhead is 5-7% smaller than transport stream, .mkv can have problems with interlaced avc)
Note: Mplayer has added support for this audio now, so you can use SMPlayer on the PC to playback for example
OK it works using DGAVCDec/winamp. Now I can use TSmuxer to mux it back.
Thank you very much for your help and fast reply.
Originally Posted by poisondeathray
H264/AC3 (MKV) to H264/AAC (MP4) ?
By jccca in forum Video ConversionReplies: 10Last Post: 13th Dec 2008, 20:06 -
h264/AAC mkv -> h264/AAC mp4?
By joshwa in forum Video ConversionReplies: 7Last Post: 4th Jan 2008, 12:08 -
projectx - demux dvb subtitles problem
By gorang in forum Newbie / General discussionsReplies: 1Last Post: 22nd Mar 2006, 14:25 -
DVB-T with sync issues after demux.
By Burbruee in forum DVB / HDTVReplies: 3Last Post: 29th Aug 2005, 15:26 -
Help! Trying to demux DVB Transport Stream with ProjectX
By bcsman in forum Video ConversionReplies: 0Last Post: 9th May 2005, 00:09
Statistics
Newest guides
Latest tool updates
New media comments
