VideoHelp.com Forum
  1. I've capped an old PAL VHS to MPEG-2 with the EasyCap. The video has 'mild' dropouts, which manifests as frozen frames, but video and audio is in sync in the final file.
    Now I want to crop and denoise the video, so I run it through DGIndex and some Avisynth filters. Problem is that now the stream elements no longer match. The sound runs more than 10 seconds longer than the video.
    I've made test caps from air, and there are no sync problems there, and re-capped the vhs with the same bad result, so I'm pretty sure the vhs instability causes frame drops.
    Question is: is there any way to process the streams and keep the sync?
    If the cap plays normally in a directshow player (resyncs itself) , you could try DirectShowSource() instead of DGIndex
    Another option is to cut out the bad sections and process in segments
    Another option is to add blank frames or freezeframe() to the video, so it matches audio
    Running it through something like videoredo's quickstream fix might help (unlikely)
  3. DirectShowSource() almost worked. The sound is now in sync when previewed in VirtualDub, but the encoded file is out of sync.
    Videoredo's quickstream fix removed some audio frames, but did not sync it.
    These problems drive me crazy! I wish someone had a good solution.
  1. Audio/video out of sync after demux-remux
    By CarryNL in forum Subtitle
    Last Post: 14th Sep 2011, 14:31
  2. MP4 demux, transcode, remux => audio out of sync?
    By julesh in forum Video Conversion
    Last Post: 10th Feb 2011, 20:00
  3. demux m2ts streams and remux them together with srt subtitles
    By TwilightMatt in forum Video Conversion
    Last Post: 9th Dec 2009, 11:10
  4. Demux mkv -> remux Divx
    By nsx3000 in forum Video Conversion
    Last Post: 15th Sep 2009, 09:12
  5. can not remux after demux
    By volam in forum Editing
    Last Post: 19th Mar 2009, 15:36
