VideoHelp.com Forum
  1. Member neo*2's Avatar
    Hi, I'm trying to convert a MKV file to dvd. After it is burned to dvd the audio is not in sync. Can anyone direct me to a guide which would show me how to adjust the sync issue? Here is the video/audio info of the source file.
    Format : Matroska
    Video
    Format : AVC
    Format profile : Main@L3.1
    Format settings, CABAC : No
    Format settings, ReFrames : 1 frame
    Muxing mode : Container profile=Unknown@3.1
    Codec ID : V_MPEG4/ISO/AVC
    Duration : 15mn 33s
    Width : 800 pixels
    Height : 450 pixels
    Display aspect ratio : 16:9
    Frame rate : 29.970 fps
    Standard : Component
    Resolution : 24 bits
    Colorimetry : 4:2:0
    Scan type : Progressive
    Audio
    Format : AAC
    Format version : Version 4
    Format settings, PS : Yes
    Codec ID : A_AAC
    Duration : 15mn 34s
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Resolution : 16 bits
    I assume the mkv is in sync?
    Try something else, like avstodvd, favc, thefilmmachine or convertxtodvd(trial).
  3. Member neo*2's Avatar
    Yes the MKV plays fine. So dvd flick was the only software that produced a decent convert other than the audio sync problem. I will try the filmmachine to see how that works out. Otherwise is there a way to sync the audio and video in the newly converted dvd file?
    You would have to demux the video and audio, then remux with an appropriate delay, then author it back in to the DVD, or author a new one.
    Another alternative is to create a simple avisynth script to load the file, and convert from that.
    Read my blogs here and here. Change England's Libel Laws - Sign Here
  5. I consistently encountered similar a/v sync issues with DVD Flick. It's too bad because it otherwise seems like a great free tool.
  1. DVD FLICK audio sync probs
    By dalek7 in forum Authoring (DVD)
    Last Post: 19th Aug 2010, 02:14
  2. Audio out of Sync with DVD Flick
    By kawyboy in forum Video Conversion
    Last Post: 5th Apr 2010, 21:51
  3. DVD Flick- audio out of sync and subtitles wont show
    By gogumakilla in forum Authoring (DVD)
    Last Post: 4th Nov 2009, 03:09
  4. Audio Synch Problem with DVD Flick
    By alhenderson in forum Authoring (DVD)
    Last Post: 3rd Jan 2009, 17:59
  5. Audio problem with DVD FLICK
    By mart59a in forum Audio
    Last Post: 20th Jan 2008, 14:54
