Hi
I have this "Six Feet Under" TV Series
First DVD Consist of 3 episodes which all of them are located in the VTS_01
I've seen other Tv Series DVD that each episode is placed in a different VTS
like VTS_01 for episode 1 and VTS_02 for episode 2
my questions is how can I add subtitle to a DVD like this when all episodes
are located in VTS_01?
can I do it with DVD Lab Pro?
If the episodes each have their own title/PGC, you add them like you would any other subtitle. If they're contained within the same title/PGC, then you have to join the subs before adding them. If you don't know which you have, open the DVD in VobBlanker. Highlight the VTS where these episodes are located so that it appears in the lower window. Then post a pic.Originally Posted by hellbound
I have no idea whether or not you can use DVD Lab Pro for the job (although you probably can). I'd do it using other methods.
Thank u for your help
I checked it and the episodes are in different PGCs
but how can I insert them in my project in dvd lab pro?
because I figure that I just can insert one video file in a project?
Of course after demuxing the dvd
Like I said, I use other methods. Here, you might try Baldrick's Method 2 as outlined in his guide here:
http://forum.videohelp.com/topic338721.html
Problem adding subtitle in MKV
By burple in forum SubtitleReplies: 2Last Post: 7th Nov 2011, 10:34 -
Tools for demuxing DVD Subtitle and adding Subtitle file to Blu-ray file.
By wisitch in forum SubtitleReplies: 3Last Post: 5th Jul 2011, 13:31 -
Need help adding a subtitle to a DVD.
By chris4556 in forum Newbie / General discussionsReplies: 7Last Post: 24th May 2011, 21:12 -
Any idea about this problem ( adding subtitle to a Dvd )
By khatab1 in forum SubtitleReplies: 4Last Post: 15th Sep 2008, 11:05 -
DVD Flick Problem adding subtitle
By MindF in forum SubtitleReplies: 1Last Post: 2nd Apr 2008, 11:49
Statistics
Newest guides
Latest tool updates
New media comments
