VideoHelp.com Forum
    I have dvd-r's from my panasonic dvd recorder that unavoidably are coded in 4:3 (many recorders wont flag for widescreen, as you probably know), although they should be 16:9. played through a tv this is fine as the tv will resize to fit the screen, on a laptop they appear tall and squeezed in.
    I'm looking for a simple program that will let me rip these to h/x264 with 128k mp3, that will automatically correct the ratio to 16:9, without zooming and cropping part of the picture or creating black bars.
    Also, what other settings would you recommend? I'm looking for the best way to encode 1½ hour movies to about 750Mb avi's.
    2-pass encoding?
    what frame size for standard def picture on a 32" widescreen tv?
    I would probably just convert to a 16:9 resolution like 640x360, 688x384, etc . Use for example handbrake, staxrip, megui(using the one click-option), xvid4psp to convert to mp4,mkv h264 with mp3 audio.
    x264 has a Sample AR setting. Set it to 16:11 for PAL DVD sources encoded with a 720x576 frame size. Not all players will respect this though.
  1. Replies: 5
    Last Post: 27th Feb 2012, 19:00
  2. LINUX: AVI to DVD Encoding and Authoring : BASIC
    By disturbed1 in forum User guides
    Last Post: 5th Feb 2010, 20:43
  3. Progressive AVI encoding to DVD in TMPEnc - interlaced?
    By GavSalkeld in forum Authoring (DVD)
    Last Post: 9th Jan 2009, 11:01
  4. Encoding avi to dvd
    By macbuz in forum Mac
    Last Post: 8th Jan 2009, 01:01
  5. Replies: 0
    Last Post: 27th Jul 2007, 09:12
