    I recently became familiar with the blu-ray ripping process and I have a quick question. I purchased anydvd hd to remove encryption, but it seems you can only rip the entire disc and not single files. Is there any way to use anydvd or another piece of software to remove the encryption on a single m2ts file? Thanks!
    Have you just tried copy the m2ts file from the BDMV/STREAMS folder using the explorer?
    And I just tried it on a blu-ray with anydvd enabled and it worked to copy one random m2ts file and then play and edit. If you are using Windows XP you probably need to install a UDF Reader to see the files.
    Actually that's what I did do. I want to convert the m2ts file to h264 now but the file is still encrypted. Perhaps I'm understanding the nature of the encryption incorrectly?
    Have you enabled anydvd?
    Can you play the copied m2ts with mpchc for example?
    How do you convert? what app?
    I copied over the m2ts before I bought anydvd. MPC and MPCHC both say "cannot render file". I plan to convert using this tutorial:
    http://forum.videohelp.com/topic333634.html
    However the test Avisynth script fails (due to the encryption I assume). Thanks for your help.
  6. I'm a MEGA Super Moderator Baldrick's Avatar
    Copy the file again when you have anydvd enabled. I don't think you will find a way to decrypt the file from the hdd.
  1. Silly Question About AnyDVD
    By hech54 in forum DVD Ripping
    Last Post: 10th May 2007, 02:29
  2. Newbie question: AnyDVD vs. CloneDVD
    By 6MONTAGE in forum Newbie / General discussions
    Last Post: 25th Feb 2006, 04:01
  3. anydvd 5.1.2.1 beta question
    By maxxjulie in forum Newbie / General discussions
    Last Post: 19th May 2005, 20:50
  4. AnyDVD Question
    By DingoAce10 in forum DVD Ripping
    Last Post: 3rd Feb 2005, 11:11
  5. New Version 2.0 AnyDVD Software Question?
    By golfnut in forum DVD Ripping
    Last Post: 3rd Oct 2003, 11:30
About   Advertise   Forum   RSS Feeds   Statistics   Tools
