Hi, I have just bought a Blu ray player with a USB port on, so I have decided to start to convert TV episodes that I have on DVD to a divx format so I can put on a hard drive, and plug into this to play.
What's the best way to do this? I have been converting some episodes for the last week, but seems to take ages. There are 4 epiosdes per dvd. I rip the DVD to hard drive with DVD fab, and then I started using Simple DIVX to take this, put it as one big movie then split with Easy DVD splitter into their individual episodes. This was working ok, then Simple DIvx wouldn't work any more, just kept saying has stopped working. I have tried other methods, like Divx convertor, but takes ages, and then was also using DVD fab to rip eash single episode. I have just completed one series of dvd's(13 episodes) but has taken me a couple of days to do so. Is there any software I can use, that you can specify these episodes, then convert to divx, I can just walk away from and it's finished when I come back?
Thanks in advance.
Thread: Ripping DVD Tv Epiosdes to Divx
When I ripped some Seinfeld discs to avi divx I used Fairuse Wizard, open dvd, choose the episodes I wanted and settings. Done. But I don't think it can convert from a video_ts from the hdd though(just an iso or dvd drive).
Or try handbrake, choose each episode and add to queue and convert.
Many thanks. I've just downloaded that(the older free version). I don't mind just doing this straight from DVD, as most I have recorded of the Tv onto a HDD player and then burnt to DVD.
Will post how I get on!
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 24Last Post: 31st Jan 2012, 07:07 -
Beauty&Beast Blu-Ray Ripping Loses 3-Dimensionality after ripping
By KostaRae in forum Blu-ray RippingReplies: 4Last Post: 22nd Mar 2011, 04:50 -
Ripping blu-ray into divx (high compatibility) with virtualdub
By Urban20 in forum Blu-ray RippingReplies: 19Last Post: 5th Aug 2010, 19:17 -
Ripping to divx for use in car
By DikkieDick in forum DVD RippingReplies: 1Last Post: 9th Jul 2008, 22:49 -
Directly ripping hardcoded subs on DivX/AVI from DVD
By drstupid in forum SubtitleReplies: 2Last Post: 4th Jan 2008, 15:51
Statistics
Newest guides
Latest tool updates
New media comments
