VideoHelp.com Forum
    Is there a way to feed a signal through from a VHS deck to my computer using the GL2. Right now I have to record the video to the GL2 & then dub the tape to the computer. I know with some camcorders you can feed the signal straight thru, but I haven't been able to figure out how to do it with this camcorder.
  2. Member yoda313's Avatar
    You'll have to check your camcorder's manual for the specifics (try the manufacturer's website if you don't have it).
    The phrase you need to look for is "passthrough". If there is a mode called passthrough on the camcorder that should do it. Also try for something like "line in". Anything that lets you use the camcorder as input device and output at the same time.
    EDit 2- also it may not be possible with every camcorder even its dv.
    Yoda, thanks for the reply. I do have the manual & there's no mention of a passthrough. There is both composit & S inputs, but they are also outputs (same one) so it's not possible to feed a signal in and out at the same time. My guess is that it's probably not possible with this camcorder.
  4. Member edDV's Avatar
    "Passthrough", when present takes analog (composite or S-Video) in and outputs on IEEE-1394 (Firewire) to the computer. Some camcorders go into this mode when the tape is removed, others have a menu selection.
    http://www.kiva.org/about
  1. Refurbished Canon GL2- manual exposure problems
    By Ablitz52 in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 27th Jul 2009, 09:52
  2. Getting a film look with a Canon GL2
    By pbear23 in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 2nd Oct 2008, 18:17
  3. Canon GL2, XL1, XL1S, or...?
    By nopEda in forum Newbie / General discussions
    Last Post: 27th Aug 2008, 15:38
  4. Protecting Canon XM2/GL2 Lens
    By foxbox in forum Newbie / General discussions
    Last Post: 19th May 2008, 08:48
  5. Canon GL2 16:9
    By kippard in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 5th Oct 2007, 23:13
