    I've got a Flip UltraHD camcorder that saves MP4 1280x720 30fps files. I've used MultiAVCHD to convert these files to AVCHD format and burned them to DVD in order to playback in high resolution 720P on a Panasonic BD30 BlueRay player.
    The problem I'm having is that the burned DVDs show the menus properly, but when playing the actual video, I get sound but no video. Most probably my video is not AVCHD\BlueRay compliant.
    I've tried Transcode using MultiAVCHD and selected 29.970fps but I get the same problem.
    Post a mediainfo of the camera footage so we can see what it actually shoots. However it does sound like you may have to re-encode the video to get it working correctly.
    Read my blogs here and here. Change England's Libel Laws - Sign Here
    Here's the mediainfo on the video file.
    General
    Complete name : C:\Documents and Settings\Rohit.BEDROOM.000\Desktop\Part III.MP4
    Format : MPEG-4
    Format profile : Sony PSP
    Codec ID : MSNV
    File size : 39.4 MiB
    Duration : 36s 333ms
    Overall bit rate : 9 106 Kbps
    Encoded date : UTC 2009-06-21 12:25:07
    Tagged date : UTC 2009-06-21 12:25:07
    Video
    Format : AVC
    Format profile : Main@L4.0
    Format settings, CABAC : Yes
    Format settings, ReFrames : 1 frame
    Codec ID : avc1
    Bit rate mode : Variable
    Bit rate : 8 970 Kbps
    Width : 1 280 pixels
    Height : 720 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 30.000 fps
    Resolution : 24 bits
    Colorimetry : 4:2:0
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.324
    Stream size : 38.8 MiB (99%)
    Language : Japanese
    Audio
    Format : AAC
    Format version : Version 4
    Format profile : LC
    Format settings, SBR : No
    Codec ID : 40
    Duration : 36s 316ms
    Bit rate mode : Constant
    Bit rate : 132.3 Kbps
    Channel(s) : 2 channels
    Channel positions : L R
    Sampling rate : 44.1 KHz
    Resolution : 16 bits
    Stream size : 581 KiB (1%)
    Language : Japanese
    It turned out to be the fps - once I re-encoded using 23.976 as the fps, it worked fine. If only I didn't have to re-encode, what a pain that is. I would in the future opt to buy a camcorder that produces videos that are AVCHD \ BlueRay compliant.
    720p30 is AVCHD compliant. It may be some other setting in the encoder that is making it compliant.
    No, 720p30 is not AVCHD compliant. AVCHD is designed to be bluray compliant, and blu ray does not allow 720P30 format.
    http://www.videohelp.com/hd
    "Video frame size
    High Definition Video
    1920x1080x59.94i, 50i (16:9)
    1920x1080x24p, 23.976p (16:9)
    1440x1080x59.94i, 50i (16:9) AVC / VC-1 only
    1440x1080x24p, 23.976p (16:9) AVC / VC-1 only
    1280x720x59.94p, 50p (16:9)
    1280x720x24p, 23.976p (16:9)
    Standard Definition Video
    720x480x59.94i (4:3/16:9)
    720x576x50i (4:3/16:9)"
    See also: http://www.avchd-info.org/format/index.html
    I would make it 720P60 with duplicated frames (altetrnatively interpolated moiton corrected frames using MVTools in avisynth) to avoid any judder from the framerate conversion.
  7. Member ranosb's Avatar
    Try DEMUXING using Tsmuxer changing the fps of the video from 30fps 29.970, then changing the tempo on the audio -.1% to sync with the video.
  1. Best way to Convert AVCHD (.MTS) >> H.264 SD (MP4)?
    By ran007 in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 5th Nov 2011, 04:19
  2. Creating an AVCHD disc from Sony camera files (MP4)?
    By Dshow in forum Authoring (Blu-ray)
    Last Post: 11th Apr 2011, 18:01
  3. AVCHD Lite to MP4 (Panasonic TZ7 to Philips PFL8404H TV set)
    By Toftebo in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 29th Oct 2009, 10:32
  4. AVCHD (MPG) to MP4
    By Cazz in forum Video Conversion
    Last Post: 19th Apr 2008, 11:58
  5. convert mp4 h264 to mp4 xvid
    By Shaorin in forum Newbie / General discussions
    Last Post: 24th Apr 2007, 20:27
About   Advertise   Forum   RSS Feeds   Statistics   Tools
