I am having with the menu button selection on disks burned from iDVD 6.0.4. The disks I burn have 6 short films, each of which has it's own button, which can be selected from the menu screen. I have tried the disks in multiple standard DVD players.
On the menu screen, I have to push the up and down arrows on the DVD player remote to select a button that is to the right or left on the screen. If I only click the right button over and over on the remote, only half of the buttons are selectable. It confuses people that I give the DVDs to and they send them back.
I have seen on the apple support forums that some people are having this trouble in iDVD 08 and iDVD 09 too.
My question is that if I import the my movies from iMovie into Toast 10 and use that to burn a DVD, will I be able to select all six of my short films using only the right or left arrows on the DVD remote? Will the button light up in order? Or, might I have the same problem I am having with DVDs burned in iDVD?
I am wondering if I should buy Toast to produce a more professional looking DVD menu that works properly?
Results 1 to 1 of 1
Add a PLAY ALL button in iDVD?
By Huntr777 in forum MacReplies: 17Last Post: 6th Apr 2011, 18:58 -
Changing the order of chapters in idvd
By caspera in forum MacReplies: 3Last Post: 16th Sep 2009, 01:34 -
Toast vs. iMovie/iDVD which is better for Mac?
By HowardNeedsHelp in forum MacReplies: 13Last Post: 2nd Sep 2009, 10:42 -
iDVD / Toast Compression No Longer Working?
By toxicquack in forum MacReplies: 3Last Post: 26th Jul 2009, 11:57 -
Fixing Chapter Selection Button (Link)
By sbernstecker in forum EditingReplies: 0Last Post: 14th Jul 2008, 13:27
