hi
i am about to buy lg ggw h20l but not sure if this drive will work with KPROBE soft to check quality of media errors PI/PO...
anyone knows or can try it home if you have it?
thanks
Results 1 to 9 of 9
Nope,only liteon drives and other drives which are built by liteon but rebadged by others.
Ben Johnson-I didnt take any stereos!
You may be aware of this, but a alternative is Nero DiscSpeed. Maybe not in the league of KProbe, but usable.
so if i buy liteon bluray burner, it should be able to work with kprobe to check quality even of bluray discs?
Yes with kprobe 2.52 but doesn't work with the DH-4B1S or DH-4O1S
so what bluray burners do work with kprobe 2.52 to check quality of BD-R (DL) right now?
any list is available so i know what to choose?
@deejay.2001 - A lot of people whose opinion I respect around here have pretty negative opinions about the whole process of doing quality scans. I'd like to politely suggest that maybe it's just really not all that important, but if you're already worried about using it with BluRay discs, I don't think you're willing to consider that viewpoint.
Kprobe is old school....as redwudz pointed out use CD/DVD speed which is now called OPTI DRIVE CONTROL.
http://www.cdspeed2000.com/
Samsung, Plextor and Benq drives are used for quality scans. Quality scans can be helpful when you run into a disc that can't playback correctly. Check out CDFreaks.com in the OPTICAL DRIVE FORUM such as LITEON, PLEXTOR, SAMSUNG, BENQ, PIONEER...etal.
compatible files
By woody12 in forum Media Center PC / MediaCentersReplies: 1Last Post: 17th Jan 2011, 11:43 -
Compatible RAM.
By A Traveller in forum LinuxReplies: 3Last Post: 10th Oct 2009, 10:44 -
What does HDTV compatible mean?
By optimus in forum DVB / HDTVReplies: 27Last Post: 6th Feb 2009, 03:19 -
Vista compatible?
By Slowburn in forum DVD RippingReplies: 2Last Post: 14th Jun 2007, 10:55 -
Want More Memory - Is This Compatible?
By daamon in forum ComputerReplies: 5Last Post: 5th May 2007, 09:19
