Hi,
I need to transcode ".mpg" h.264(mpeg4) files to mpeg2.
The h.264 file has embedded subtitles (I think they called dvb subs?)
Currently I am using ProCoder3 for the transcoding but when is done the subtitles are not included in the new mpeg2 file (.m2t)
Is there a program for transcoding, that can keep the embeded subtitles ?
I tried also to use tsMuxeR to mux the converted .m2t file with external .srt subtitles file (specification of the tsMuxer says that transport stream is supported)
The m2t file is not supported by the tsMuxer but if I rename it to .ts the tsMuxer can open it.
I run the tsmux, the audio and video are there but no subtitles.
Any ideas ?
(p.s I prefer to not hardcode the subs on top of the video but keep them inside the transport stream as dvb subs)
Results 1 to 1 of 1
MPEG2 to H.264 Conversion question
By tonyaldr in forum Video ConversionReplies: 19Last Post: 5th Apr 2012, 08:06 -
can tsmuxer change h.264 mov to m2ts files without reencoding?
By Onceler2 in forum Video ConversionReplies: 2Last Post: 20th Mar 2012, 04:47 -
Embedded subtitles
By dexter30 in forum Newbie / General discussionsReplies: 1Last Post: 13th Sep 2010, 15:07 -
Empty audio files when converting MPEG2 with h.264 mencoder or h.264 x264
By doctormelodious in forum ffmpegX general discussionReplies: 3Last Post: 4th Jul 2010, 08:12 -
No Videio after using TsMuxer on H.264 5.1 -> H.264 4.1
By Le0Heart in forum Video ConversionReplies: 0Last Post: 23rd Feb 2009, 03:42
