    hi, i've got thie 2:39 concert on my computer and i'D like to encode it onto a dual layer dvd to have the best possible quality.
    the file is an mp4 with h.264 encoding
    how can i do this with ffmpegx?
    thanks
  2. Explorer Case's Avatar
    I assume you're going for MPEG-2 DVD-Video then. Note that transcoding always affects quality, so your source file's quality may not be matched through a magnifying lens.
    Dual layer will hold about 7.92 GB = 8110 MB.
    The Bitrate Calculator then tells us that for that file size, and say 160 minutes, you may have an average video bitrate of 6561 kbps.
    The number will appear in blue, saying that such a bitrate is more than it actually needs for good quality video.
    For 'best possible quality', you may set the Qmin from 3 to 2 for slightly better video at the cost of higher bitrates at peaks when needed/ when it can.
    You may notice that the output is possibly a bit smaller than 8110 MB. This means that the encoder didn't need all of the high bitrate to encode in the best possible quality. If it needs a certain amount of bytes to describe a scene best, then there is no use in wasting more bytes.
    Set Autosize to 'DVD 16:9' for widescreen content.
    Check 'Set 3:2' for 23.976 fps content.
  1. dual layer DVD-R in single layer burner?
    By snafubaby in forum Media
    Last Post: 4th Oct 2007, 14:39
  2. Need help ripping/burning back-up of dual-layer dvd on dual-layer burner...
    By bloomcounty in forum Newbie / General discussions
    Last Post: 20th Mar 2007, 16:18
  3. Double Layer (Dual Layer) DVD+R for video?
    By C53248 in forum DVD & Blu-ray Writers
    Last Post: 31st Oct 2004, 11:28
  4. First Dual Layer burn news, now Dual layer disk. RITEK DL
    By Faustus in forum Latest Video News
    Last Post: 21st Mar 2004, 16:40
  5. dual layer to single layer dvd. few problems, please help!!
    By lammypie2001uk in forum DVD Ripping
    Last Post: 31st Mar 2003, 10:18
About   Advertise   Forum   RSS Feeds   Statistics   Tools
