Hi,
Just thought I'd give this a mention, as I've never known any other media to burn as much as 4.99GB (actually nearly 5.4 GB, when viewing the total size on disc via the properties option). So if your lucky enough to be living in the UK and can get to your local ASDA lol, you may want to consider picking a pack of these up.
They are basically Siver (Face Side) Blue (Recordable Side). The ASDA Logo in situated Top Center of the disc, on the left side of the disc it says Single Use & Single Sided underneath, and on the right hand side it says 4.7 GB and underneath says 16x Speed.
I burned a mixture of data to the disc including Software, MP3's, Flash Files, etc using ImgBurn v2.5.0.0. At the end of the recording, ImgBurn reported that it had a problem finalizing the disc, and offered to try and resolve this problem, in which it did.
I've tested nearly everything on the disc, and can say I've had no problems with corrupt data whatsoever! Happy Hunting.
CDFS? Something is being read wrong, I'd bet.
Answers to Common Video Questions:
Best blank discs • Timebase Corrector FAQ • Best VCR for capturing • Help restoring video
I smell bullsh!t.
ASDA a.k.a. Walmart
Can you get the DVD info?Regards,
Rob
Ok, just did a disc scan on the media, and it is showing .9% out of 100% in corrupted data
. Oh well, sorry for the mistake, just the first time I've ever come across a disc that's stated what it shows above, but yet still be able to finalize the disc and show it's contents.
Yep, the disc is fubar, bad results reported.
Video files I add more for a burned disc won't read on my DVD recorder
By Indrek in forum DVD & Blu-ray RecordersReplies: 5Last Post: 8th Jan 2010, 07:30 -
asda Pacific 1001. Does it play DVD-RWs?
By zakrocz in forum DVD & Blu-ray PlayersReplies: 15Last Post: 3rd May 2009, 13:33 -
Audio is skipping when I play videos that are burned on a Data disc DVD!
By Xenogear900 in forum Software PlayingReplies: 8Last Post: 23rd Mar 2009, 13:12 -
Dual Layer DVD successfully burned, but won't play on a DVD player Help Plz
By Ruudboy in forum Newbie / General discussionsReplies: 9Last Post: 13th Dec 2008, 02:09 -
Burned dvd video disc has no sound
By funnybunny in forum Newbie / General discussionsReplies: 1Last Post: 24th Sep 2008, 15:00
