Hi Good Peoples,
I am hoping someone hear can help me please. (I have done some searching but have not been able to find the answer.)
I have ripped my DVD's using DVDFab with no problems. They are ripped at 16:9. I am using avi.net to convert them so I can add them to my Egreat.
After the file has been indexed and the options come up, there is an option for "screen size." However it does not show 16:9 or anything that makes a lot of sense to me. The drop-down option box shows numbers like Width 720 0r 640 etc.
The red info shows (for example) "DVIX Size 1120MB 0.21 2.35:1 640x272"
(I am using the Divx7 avi codec option.)
Can anyone please tell me how I get it to output at 16:9 please?
Cheers
Ric
If you rip it at 16:9 it wil add black borders on the top and bottom,any reason you need to do that?The egreat player should display it at the right ratio.
Ben Johnson-I didnt take any stereos!
The DVD aspect ratio is not necessarily the same as the movie aspect ratio (the actual content)
Does the DVD have letterboxing ? (black border on top & bottom) i.e. is the aspect ratio of the movie 2:35:1 or something else?
Thanks for the response.
It doesn't give me the option of 16:9 and I thought that was what was required as it was the input size according to DVDFab.
All I want is the right (best size) picture on my SD 104cm TV.Cheers
Ric
Avidemux aspect ratio question [from newbie to Avidemux]
By ANOther1676 in forum EditingReplies: 1Last Post: 20th Jan 2012, 20:07 -
how to determine aspect ratio of clip for DVD output?
By perfection in forum Newbie / General discussionsReplies: 5Last Post: 31st Oct 2011, 01:02 -
Video output won't keep aspect ratio on a TV
By Skarett in forum Newbie / General discussionsReplies: 15Last Post: 28th Apr 2008, 06:40 -
Joining AVI files, what should the output width/heighth ratio be?
By proudfrog in forum EditingReplies: 5Last Post: 17th Mar 2008, 23:48 -
DVD player audio output question
By Des in forum DVD & Blu-ray PlayersReplies: 4Last Post: 21st Feb 2008, 12:20
Statistics
Newest guides
Latest tool updates
New media comments
