Hi
Is there an easy noob way to enhance an old VHS movie that I already converted to mpg ?
Thread: restoring an old VHS
Maybe. What's wrong with it?
Describe the problems.
Answers to Common Video Questions:
Best blank discs • Timebase Corrector FAQ • Best VCR for capturing • Help restoring video
Some parts of the film are very white, but all the film is very "blurry"
I've attached a sample
On the left shows what happened in some sections of the video
The other image shows how the rest of the movie is, too blurry. There are some sections worst then on this image.
I can digitallize the video again, since I have the tape, and I still own a functional VHS
Probably there is something I can do to make a better mpg file, before I enhance it.
Note:
I'm not a noob in the computer world, but I'am a noob, very noob, in video editing/processing...
If that is what the tape looks like then you will have problems getting much out of them. The whites look very hot, so there is little to no detail left in them to restore.
Looks like you will be capturing again. You need to spend some time tweaking your capture settings. Bring contrast down and set gamma at 1 (or 100% which ever your software calls it). If there is a setting for "gain" then you will want to bring it down as well.
Darryl
Sometimes consumer VCRs overly add contrast, and then some capture devices will do this to video it thinks have "copy protection" (even if it's homemade, obviously).
To get really great captures you'll need a good S-VHS deck with line time base correcter, noise filtering and sharpening; a full frame time base corrector; and a video processing amplifier to adjust levels and colors. All that will cost you about US$1000. Then you'll probably have to capture shot by shot with adjustments taylored for each shot.
If you are unwilling to purchase all that equipment you can at least adjust the levels (brightness, contrast) at your capture device. That will hopefully get you some details in the washed out bright areas and better contrast. If you can, capture uncompressed or losslessly compresssed (huffyuv, lagarith). That will allow you to run sharpening and other filters without accentuating the MPEG artifacts. But there's a limit to how much you'll be able to sharpen without making the video look worse.
Filters for restoring old VHS
By elbenno in forum RestorationReplies: 18Last Post: 9th May 2011, 13:46 -
Repairing/Restoring a VHS?
By Veepa in forum RestorationReplies: 0Last Post: 5th Nov 2010, 13:26 -
Restoring old VHS and Hi8 captured videos with Premiere
By alegator in forum EditingReplies: 1Last Post: 4th Oct 2010, 05:07 -
Restoring VHS tapes with a mix of NTSC and PAL-M encodings?
By leon43 in forum RestorationReplies: 5Last Post: 24th Nov 2008, 05:31 -
Anything is possible when cleaning up/restoring VHS.
By StuartB4 in forum RestorationReplies: 15Last Post: 10th Oct 2007, 06:58
