Hello all!
I am in the process of ripping footage from a DVD from a live performance to mix together with stuff I am shooting in a stage.
It has been so long since I have had to do this, that I am in need of some sage advice. I have downloaded MPEG Streamclip and have been using the DV/NTSC Pro output to drop into FCP. However I am really worried about any quality loss so I switched over to the Apple FCP 10 bit uncompressed codec
Is this the best thing to do or is there a better codec or output setting to use to get the best quality from a DVD to a NTSC project?
Thanks much!
Results 1 to 1 of 1
Help! How to convert mpeg-2 file with LPCM audio to Final Cut Pro?
By afireinside181 in forum Video ConversionReplies: 3Last Post: 31st Oct 2011, 18:59 -
convert h.264 to use in Final Cut Express. Streamclip problem
By robinhall in forum Video ConversionReplies: 2Last Post: 28th Mar 2010, 15:54 -
convert H.264 to use with Final Cut Express. Streamclip problem
By robinhall in forum MacReplies: 1Last Post: 28th Mar 2010, 15:41 -
MPEG 2 to Final Cut Pro - No Audio
By Huntr777 in forum MacReplies: 5Last Post: 5th Jul 2009, 19:14 -
Mpeg Streamclip and Final Cut Pro .mpeg...Only 1 hour clips?
By checksum in forum MacReplies: 10Last Post: 16th Dec 2008, 23:38
