hey just wondering if i can sync audio on avi files. my aim is to make a data disc so i can play them in dvd player or xbox 360.
is there a way i can batch sync them, caus i hav a lot of episodes and it would be to hard to edit them individualy
any advice would be great
AVI Demux will let you sync audio by adding or subtracting a delay to the audio. It won't batch though.
The question I have is why you have so many files with a delay issue. Audio sync issues should be a rare problem. If you have a lot of files that have this issue then you have either done something very wrong when you created them, or have some other issue affecting playback (assuming you did not create them)
welll originaly they wer rmvb files that i converted, using ffmpegx. they wer really small files averaging bout 31mb there quality wasnt heaps goood once i changed them to avi.
is there any setttings i should change in the converting process?
Short answer is yes, you need to change the settings to get better output. I don't use ffmpegx, so I don't know what settings you used, or should use, and I hate RMVB format video so I never deal with it.
its a goood file for downloading but not for formating and converting.
does anyone no wat settings i should use?
Audio/video fine on PC, out of sync on Mac
By scrolls in forum Newbie / General discussionsReplies: 1Last Post: 31st Jan 2012, 21:48 -
audio video avi file out of sync when converting with nero
By paulthewall37 in forum AudioReplies: 2Last Post: 28th Feb 2010, 18:06 -
Audio Sync Problem, Repairing and AVI File?
By JerryRecords in forum AudioReplies: 1Last Post: 4th Dec 2008, 23:38 -
How do I audio sync an .avi file on a mac?
By monster_prodigy in forum MacReplies: 3Last Post: 19th Mar 2008, 16:34 -
Audio out of sync in AVI file by varying amounts
By smc888 in forum Newbie / General discussionsReplies: 3Last Post: 4th Jul 2007, 11:23
