VideoHelp.com Forum
    hi just needing a bit of advice im new to this forum so correct me if iv done something wrong.
    iv searched countless posts with no clear direction.
    i hav a bunch of rmvb files that iv converted on ffmpegx to avi, which i then put on a data disc to watch in xbox 360 n dvd player.
    But the sound is a bit out of sync. just wondering if there are any settings i can change on ffmpegx, so it comes out better. like up the quality or something,
    or if i should convert to something befor goin straight avi.
    or if theres a program thatl do it after
    just keep in mind theres like 300 episodes n dont reallly want to edit them individually
    any advice willl be most appreciated
  2. Member AlanHK's Avatar
    I don't know if you can use Avisynth on Mac, but I do it like this in Windows, with a source nominally 25 fps:
    DirectShowSource("file.rmvb", fps=25, convertfps=true)
    EnsureVBRMP3sync()
    That kept it in sync.
    yeah i tried to do that on ffmpegx couldnt figure out wat convertfps=true was
    but it seemed to help a bit stilll not perfect tho
    thanks for the help tho
  1. SSD tips-n-tricks?
    By Moontrash in forum Computer
    Last Post: 20th Dec 2011, 17:14
  2. Anyone Own 101 Tips & Tricks For Sony Movie Studio?
    By V Bot in forum Authoring (DVD)
    Last Post: 7th Feb 2011, 19:43
  3. Panasonic Tips and Tricks
    By zorankarapancev in forum DVD & Blu-ray Recorders
    Last Post: 5th Apr 2010, 21:28
  4. Replies: 1
    Last Post: 29th Aug 2007, 22:30
  5. Tips and Tricks
    By squallheart in forum Video Conversion
    Last Post: 9th May 2007, 13:50
