VideoHelp.com Forum
Results 1 to 11 of 11
    I want to be able to turn HD TS files to (SD) DVD to send to a relative.
    I tried the free HDTV2DVD but although it appears to run (i.e. no errors) it only encodes the sudio. I then tried the demo of SVCD2DVD and this worked fine (within its limitations). I thus splashed out on the full version (2.5) and it throws up several error messages including this one:
    Version: SVCD2DVD 2.5
    Build: 2.5.5030.0
    Type: System.AccessViolationException
    Source: SVCD2DVD
    Message: Attempted to read or write protected memory. This is often an indication that other memory is corrupt.
    InnerException:
    StackTrace: at x3284ccece41ee22b.xd3764d4f1e921081.AuthorDVD(xc76 139390a97debb xd2637df501625a82, x81974c36d7fdf1e1 xb4ee5c1758e9e983, Int32 xdc4f66b5011a3c9d, String[] x738d70b20493db82, Boolean x6b20cb17e8070d92, Boolean x3c21da9f928aac10)
    at x3284ccece41ee22b.xd3764d4f1e921081.x2e6504f39decc 498()
    at x3284ccece41ee22b.xd3764d4f1e921081.xf81783e1b359f fc3()
    at System.Threading.ThreadHelper.ThreadStart_Context( Object state)
    at System.Threading.ExecutionContext.Run(ExecutionCon text executionContext, ContextCallback callback, Object state)
    at System.Threading.ThreadHelper.ThreadStart()
    Any suggestions as to the problem gratefully received.
  2. VH Wanderer Ai Haibara's Avatar
    You might have better luck getting an answer in the SVCD2DVD forum, here on VideoHelp, which the author (ChrissyBoy) frequents, though that's not the only area of VideoHelp he visits. Still, if you would like a moderator to move this post to that forum, just click on the Report This Post link at the bottom of your post, and mention it.
    Have you tried running the program as an Administrator? Or in XP compatibility mode?
  3. Mod Neophyte Super Moderator redwudz's Avatar
    Moving you to the SVCD2DVD & VOB2MPG Forum.
    And welcome to our forums.
  4. Are you running SVCD2DVD as administrator? Did you install to directory other than 'Program Files'?
    http://forum.videohelp.com/topic324278.html#1776530
    Dwight
    "A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
    - Herm Albright
    www.martialconcepts.com
    OK - read some suggestions and re-installed with folder directly in C drive (not in Program Files). Running as Administrator but still no joy - same error messages. Also will no longer play assets which DID work before (get continual rotating icon with lots of disc activity, and program appears to lock up).
  6. Member ChrissyBoy's Avatar
    Build: 2.5.5030.0
    Source: SVCD2DVD
    InnerException:
    Can attach your log for this run please? (find logs via the help menu)
    How about this one
    svcd2dvdlog-20090827103736.txt
  8. Member ChrissyBoy's Avatar
    Looks like a problem with the 2 pass.... can you try without that option please?
    OK - seems to be progressing this time with one pass encode set - I have to go out but I'll tell you the final result in an hour or so.
    That leaves the problem of why the asset play won't work? I went back to HDTV2DVD and it now doesn't work on that either. Could it be a problem with FFDSHOW?
    It finished making a DVD from a single 30min HD movie (H264 TS) in just over 2 hours (not inc burning). Trouble is it has produced a VideoTS of 3.4GB which is way over max bit rate! Still at least it is running now, so I'll try tweaking a few things.
    I did another with the 'Safe Max Bitrate' button pressed but it still comes out over 3GB for the VideoTS which is over the max DVD rate even for an average! It is curious since the bar graph in the SVC2DVD main panel shows under 2GB which would be OK. FWIW I've attached the log for this last session.
    svcd2dvdlog-20090827161911.txt
  1. Vista install problem
    By Perfik in forum SVCD2DVD & VOB2MPG
    Last Post: 23rd Feb 2011, 06:01
  2. SVC2DVD quit working on VISTA SP2
    By artar in forum SVCD2DVD & VOB2MPG
    Last Post: 25th Aug 2009, 17:01
  3. SVC2DVD not working on Vista
    By davezim in forum SVCD2DVD & VOB2MPG
    Last Post: 20th Aug 2009, 07:02
  4. Burning a few .AVI files with SVC2DVD
    By geek2330 in forum SVCD2DVD & VOB2MPG
    Last Post: 7th Sep 2008, 09:49
  5. SVC2DVD 2.5 crashes when installed in Vista Ultimate
    By paparay in forum SVCD2DVD & VOB2MPG
    Last Post: 4th Oct 2007, 04:04
