VideoHelp.com Forum
    Hello guys,
    I have a question related with subtitles, I do the conversion fine but I have a problem with subtitles, on the preview button they appear in a perfect quality but after converting avi to dvd, the subtitles loose a lot of quality.
    Anyone knows why they loose quality ?
  2. Explorer Case's Avatar
    Originally Posted by somenho
    why?
    The Preview uses mplayer to render the text subtitles in real time using the full color space and anti-aliasing, while the selectable DVD subtitles are rendered by a different tool, and also in a limited color set (2 bits per pixel, as per DVD requirement) without anti-aliasing. If the used font is thin, like a standard Arial, this is more noticeable. A commercial DVD will often have a semi-bold font, to lessen this effect. The enlarged subtitle below shows this on a commercial title. Don't expect better results with selectable subtitles.
    Thanks Case for the reply I will try with another type of font and see the results ,)
  1. Replies: 3
    Last Post: 2nd Jun 2011, 23:28
  2. Converting HD-DVD subtitles To BLURAY subtitles
    By wulf109 in forum Blu-ray Ripping
    Last Post: 31st Dec 2010, 09:54
  3. converting subtitles from avi to dvd???
    By denze1 in forum ffmpegX general discussion
    Last Post: 11th Feb 2010, 11:39
  4. help with converting AVI to DVD with subtitles
    By Pariah in forum ffmpegX general discussion
    Last Post: 7th Mar 2008, 23:28
  5. Replies: 5
    Last Post: 9th May 2007, 20:49
