I have been collecting music videos for some years now and it has never been a problem until now. While newer videos are avi the older are always MPEG and now I have encountered audio problems with a few of these older files.
Example:
when I look at info on a file it says MPEG1 Muxed. This file has an audio sync problem. It seems the video is running slower than the audio.
Another example is a file that says MPEG2 Muxed and here I can add start and end points but when I trim the file video is removed. Other MPEG2 Muxed files show none of these sympoms and can be trimmed and edited normaly.
I use Mpeg streamclip for my MPEGs and it has worked in the past. On a side note I tried to use QT to export the whole clip to another more QT friendly format but when I try this the program says there isn't any audio tracks.
I turn to you for help as I have done in the past. What more information do you need to help me solve this problem? Thank you all
/Kim
Thread: MPEG1/2 related audio problems
FPS-related problems in Premiere when importing a video (solved)
By quandore in forum EditingReplies: 4Last Post: 4th Nov 2010, 06:04 -
Need help with burning DVDs (audio related)
By JediMindTrick in forum Authoring (DVD)Replies: 3Last Post: 29th Mar 2010, 18:10 -
TMPGEnc Xpress 4.7.4.299 crashes at 50%; audio related
By CasanovaFly in forum Video ConversionReplies: 0Last Post: 28th Mar 2010, 22:20 -
NTSC-PAL-NTSC (25-23.976+pulldown) and audio sync problem - related?
By ecc in forum Video ConversionReplies: 14Last Post: 14th Nov 2007, 11:34 -
Vegas4 and mpeg1 problems
By Flemo in forum EditingReplies: 0Last Post: 25th Aug 2007, 19:27
Statistics
Newest guides
Latest tool updates
New media comments
