My Sandisk 4gb cruzer US stick won't fit in the opening for the USB drive of my Epson NX415 printer. The USB connection is recessed in the printer and the outer plastic covering doesn't allow the case of the cruzer to pass thru it.
Before I take the printer back I was wondering if there's any type of extender I could plug the USB stick into. I have several USB sticks - none of which can get past the opening of the printer.
thanks
Thread: USB stick won't fit in printer
Yes, there are USB extension cables that would resolve this.
FB-DIMM are the real cause of global warming
thanks, I saw some $30 or so priced ones on BestBuy and figured there had to be something much cheaper. Put 'usb extension cable' into Ebay and found the 'extension cord' type thing I needed for a couple of bucks.
Do you have a Dollar Tree, 99 cent store or Big Lots near you? All of them have USB extension cables for a buck.
playing film from usb stick on tv
By dougvcd in forum Newbie / General discussionsReplies: 11Last Post: 19th Aug 2010, 11:43 -
is anyone aware of this usb stick issue?
By SE14man in forum Newbie / General discussionsReplies: 4Last Post: 17th Aug 2010, 10:19 -
Only SOME of the jpg:s on my USB stick can be displayed by the TV
By anla in forum DVB / HDTVReplies: 3Last Post: 1st Nov 2009, 05:44 -
question about fake USB memory stick
By jimdagys in forum ComputerReplies: 12Last Post: 30th Mar 2008, 23:58 -
USB memory stick recommendation...
By retroborg in forum ComputerReplies: 5Last Post: 12th Sep 2007, 06:55
