I am running VISTA x64 SP2. SVC2DVD did run on this machine before installing the latest updates (including SP2) to VISTA. I have the latest version of SVC2DVD 2.5.5030 installed in it's own directory and set to run with OWNER permission. I click the icon and the SVC2DVD splash screen comes up and stays on the screen for about 15 sec and then it shuts down. No error messages, nothing in the application log files. Task manager shows the file running while the splash screen displays and then everything disappears. Any ideas would be appreciated.
You just need to reinstall it.
I wish it were that easy. I have uninstalled, rebooted, reinstalled, rebooted. Tried it in the Program Files (x86) folder, tried it in it's own folder on the root. Same results.
So did you register? Or is this before that?
The program installs and goes through the registration just fine. When the registration is finished it asks if I want to run the program, I choose yes, and the splash screen appears for 30-45 sec and then disappears. No error message. Every time I try to run it after that, the same thing happens.
Can you take a look at this and tell me if it is similar in your case?
http://forum.videohelp.com/topic3688...light=language settingsSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
My language settings are English (US). Like I said before, the program did work on this machine, but it has been a while since I have used it and I know Vista SP2 and several other updates have been installed since then
wma > mp3 quit working
By marleyg in forum ffmpegX general discussionReplies: 1Last Post: 25th Jan 2010, 04:40 -
Vista problem with SVC2DVD
By PerryM in forum SVCD2DVD & VOB2MPGReplies: 10Last Post: 27th Aug 2009, 13:34 -
SVC2DVD not working on Vista
By davezim in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 20th Aug 2009, 07:02 -
SVCD2DVD 2.5.5030 Not Working with Vista SP2
By k_vic in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 28th May 2009, 12:33 -
SVC2DVD 2.5 crashes when installed in Vista Ultimate
By paparay in forum SVCD2DVD & VOB2MPGReplies: 26Last Post: 4th Oct 2007, 04:04
