VideoHelp.com Forum
  1. Member Wanderlustus's Avatar
    Hey folks. Does anyone know if this unit plays MKV files? Friend of mine has a whack of MKV files from an old comedy series, but I don't feel like watching them all on my PC.
    Cheers,
    Wanderlustus
    I doubt that. I would batch-reconvert to avi xvid using for example WinFF.
  3. Member Wanderlustus's Avatar
    Thanks Baldrick. Always a helpful fellow.
    I just checked my e-mail and mate wrote this to the same question I asked in here:
    "If you want to convert to AVI then I suggest using All to AVI Converter. To retain the high video quality I suiggest using a frame-rate of 2500fps. It does however make a large file size of about 500MB per half hour episode. Lower frame rate reduces the file size and also reduces video quality"
    Does this make sense to you, Baldrick?
    Cheers,
    Wanderlustus
    That player won't play MKV files, period. It only understands AVI containers.
    Your "mate" is an idiot. He has confused frame rate with bit rate. It's a truly horrible mistake. A bit rate of 2500 Kbps when encoding should give you very good quality.
  5. Member Wanderlustus's Avatar
    Thanks for your input. While my mate may be wrong about this, I see no reason to call someone you don't even know "an idiot." Maybe you need to calm yourself a little.
    Cheers,
    Wanderlustus
    The Philips 5990 also plays MPG and MP4 containers. MP4 is limited to Divx/Xvid video and Mp3 audio. No h.264. No resolutions over 720x576. You might be able to remux your MKV into AVI or MP4 if the codecs and resolutions are acceptable.
  7. Member Wanderlustus's Avatar
    Thanks for the help on this, Jag.
    Cheers,
    Wanderlustus
  1. Philips DVP5990/F7 - burning avi files
    By ap401 in forum DVD & Blu-ray Players
    Last Post: 22nd May 2011, 09:44
  2. how 2 open mp4 & mkv video files in vdub
    By naveenkrish in forum Editing
    Last Post: 19th Jun 2010, 22:14
  3. |WIN7| Media Center & MKV files!
    By smounche in forum Software Playing
    Last Post: 14th Oct 2009, 16:20
  4. DVP5990 and WMA Files
    By Wanderlustus in forum DVD & Blu-ray Players
    Last Post: 29th Apr 2009, 23:02
  5. DVP5990/5992 problems playing some files
    By vkolli in forum DVD & Blu-ray Players
    Last Post: 7th Feb 2009, 18:28
