Hi there
I am new to editing in final cut pro and have a video that seams to be windscreen but the sequence timeline has changed it too a 4:3 layout. Does anyone know how to change it back? Your help would be much appreciated. One more thing: when i toggle the anamorphic setting it just squashes the video even more.
Kyle
Results 1 to 9 of 9
Thread: Help in Final Cut Pro video size
The picture you linked looks fine.
Check your sequence settings.
The picture on the right is the final film. And it has those black borders around the footage. I have played around with the sequence settings although am unable to get rid of the black boxes.
Thanks for your help.
Are you saying that the letterboxing I see in the Canvas window remains intact if you export the video to a QuickTime movie? You see the letterboxing then, as well?
Yes. That is exactly the problem. Any suggestions?
If the original footage appears (prior to being imported into FCP) correct (not letterboxed and in the proper proportions), then your sequence was setup as something 4:3, not 16:9.
I do not know the source of your video. When I edit footage from my SD 16:9 camcorder (which is anamorphic), I use the DV 4:3 Anamorphic setting. My footage is then imported and it stays 16:9. When I export, there's no letterboxing.
Sue,
Can you post a link where I might download a few seconds of the video footage? Perhaps I can drop it into my FCP and see what transpires.
Hi,
I had to upload it and it looks like this:
http://www.youtube.com/watch?v=248I4v7378A
Once YouTube has its way with it, it's no longer something I can examine in FCP.
(I got an error from YouTube when attempting to load it.)
Try using a free service like adrive.com where you may upload it and then make the file "public" and PM (or post) the link.
How to Import Video with Transparent into Final Cut Pro X (FCPX)
By presentation3d in forum MacReplies: 0Last Post: 27th Apr 2012, 05:36 -
Import Premier Pro 1.5 Project into Final Cut Pro/Studio 3 - how please?
By rjamesd05 in forum MacReplies: 1Last Post: 6th Sep 2010, 13:50 -
Final Cut Pro - Question about a skip in video, how to sync?
By Huntr777 in forum MacReplies: 0Last Post: 18th Oct 2009, 20:56 -
Final Cut Pro, and strobed video
By Huntr777 in forum MacReplies: 8Last Post: 16th Aug 2009, 03:23 -
final cut express and final cut pro 6
By ednarophati in forum MacReplies: 1Last Post: 16th Jul 2007, 10:05
