Yes,
I connected my Dell Optiplex to my Sony TV via a HDMI cable. The picture is great, but I do not have sound except from the PC. I have a Colorado GeForce 8400GS 128MB PCI express video card. Also, on my video card there is a set of wires with a 3- holed plug at the end which I do not have plugged into anything on my motherboard or anywhere else. I have tried fiddling with sound in control panel and the sound settings on my tv. No luck. I also have a receiver connected to my tv via RCA jacks and I am able to hear sound from my stereo when on the tv setting, and I have sound when set to HDMI 1 which has a Playstation 3 on it but not HDMI 2(which is what the computer is plugged into).
Thank you in advance,
David747
have you checked for updated drivers? sometimes theres a different driver just for the hdmi portion...ilve had issues getting my 780g hdmi audio to work on xp but it works fine on vista..
Thank you for you input. I will try that
I do have the other part of my query. Do I need to attach the 3-holed plug at the end of my video card to anything?
Nvidia chipset cards are known to have issues with SONY TV's. No need to hookup that 3 plugs. I believe that's a svideo cable w/audio.
I had to connect the spdif out from the audio card and connect that to the video card spdif in with my geforce 260gtx dvi to hdmi connection.Is there an spdif connector on the 8400?
Ben Johnson-I didnt take any stereos!
Question about hdmi connection
By sanosuke in forum DVB / HDTVReplies: 6Last Post: 24th Dec 2010, 07:16 -
multimedia player connection via hdmi but monitor doesnt have hdmi slot
By ozy666 in forum DVB / HDTVReplies: 1Last Post: 25th Apr 2009, 09:40 -
HD DVD & TV with HDMI connection
By InsideOut in forum DVD & Blu-ray RecordersReplies: 9Last Post: 2nd Apr 2008, 13:00 -
Another DVI to HDMI connection problem
By Janek in forum DVB / HDTVReplies: 6Last Post: 24th Feb 2008, 18:38 -
Philips-DVP5982 HDMI Connection help
By jimtnc in forum Newbie / General discussionsReplies: 4Last Post: 22nd Dec 2007, 04:52
