VideoHelp.com Forum
    Hi,
    I need some help on a problem that I'm running into. I have downloaded HDConvertToX and installed the required software for it. "ffdshow" "haali media splitter" "AviSynth" and "XviD". Here is the problem that I'm running into, everytime I launch HDConvertToX, I get the following message "Missing Haali Media Splitter installation Please install Haali Media Splitter". The thing is I do have Haali Media Splitter installed. I have uninstalled and reinstalled, and nothing.
    Is there something I didn't do during installation?
    Please some help.
    Thanks,
  2. Member fatbloke88's Avatar
    I vaguely remember having to install haali media splitter into the HDconvertex program files folder so that it would see it,maybe wrong as I uninstalled it some time ago,but worth a try to see if it works.
  3. what os are you using ?
    if windows 7 it's a know bug. HDC isn't able to detect haali in win7
    (to fix in next update)
    anyway you can safely ignore it, if conversion is ok
    BHH
    HDConvertToX, AutoMen, AutoMKV Developer
    I'm using Windows XP Professional SP3.
    It works now. I had to install it into the applications folder, for HDC to see haali. I originally tried what fatbloke88 suggested, before the comment, but it wasn't in applications folder.
    Thanks!
  1. Replies: 3
    Last Post: 25th Feb 2012, 18:00
  2. FFMpegSource2 does not use Haali Media Splitter
    By wateshadon in forum Editing
    Last Post: 10th Sep 2010, 06:03
  3. Gabest MP4 splitter vs. Haali Media Splitter
    By jaduvil in forum Software Playing
    Last Post: 16th Jun 2010, 11:57
  4. ffdshow & Haali Media Splitter
    By AuroEdge in forum Software Playing
    Last Post: 26th Sep 2008, 00:18
  5. Haali media Splitter Errors
    By SWBisbee in forum Newbie / General discussions
    Last Post: 16th Sep 2007, 15:45
