VideoHelp.com Forum
Results 1 to 9 of 9
    I'm looking to play videos, pics, etc. from my PC to TV. My PC is quite a distance from my TV so I wanted to go with a wireless system but I'm not sure what is best in terms of picture quality and a few reviews I read said they had less than acceptable picture quality.
    I thought maybe use my laptop, buy I only have an SVGA output and I've read the cables from SVGA to HDMI also have a blurry picture, so I thought maybe a DVD player that would play multiple formate. Then I read reviews and it said that it's hard to find a device that is able to play multiple formats and it is better to use a computer.
    Now I'm back to a wireless PC to TV device if there are any out there that are reliable, good picture and don't cost an arm and a leg.
    Any recommendations out there?
    Thanks,
    J
  2. Member SingSing's Avatar
    You need a media PC or laptop.
    There are many discounted media PCs on the cheap like this one:
    http://www.geeks.com/details.asp?inv...95N-PB&cat=SYS
    My desktop has HDMI, but my laptop doesn't. I would still need a wireless PC to TV network as my TV is in another room from my PC.
  4. contrarian rallynavvie's Avatar
    Any wireless media center extenders are going to cost almost as much as buying a basic HTPC so the choice is yours. I'd prefer the full HTPC. I think there's a long thread about a WD one in this forum.
    FB-DIMM are the real cause of global warming
    I'll look into it. I may be better off just buying a wireless television as I plan to in a few months. Thanks for the help!
  6. Member yoda313's Avatar
    Do you already own a xbox 360 or playstation 3? If so you already have all you need to network to the pc. The ps3 has built in wireless. The xbox 360 needs a pricey adapter for one - or you can get a generic wireless add on so long as it specifically states it works with the 360. From there you can use windows media player or tversity to stream.
    Just be aware that video streamed wirelessly can lag and stutter. I know this is true for wireless G. I don't have N yet so I don't know if the extra bandwidth makes that much of a difference.
    Of course dlink makes devices you can check into if your not into gaming.
  7. Member SingSing's Avatar
    Isn't these only transfer old composite signals ?
    Yes, he'd have to have composite or s-video out on his computer.
  1. Replies: 1
    Last Post: 31st Jan 2010, 15:04
  2. Replies: 4
    Last Post: 7th Jul 2009, 12:29
  3. Replies: 5
    Last Post: 2nd Nov 2007, 23:56
  4. USB Wireless lan stronger than Internal wireless?
    By Super Warrior in forum Computer
    Last Post: 6th Aug 2007, 23:26
  5. Wireless LAN with B and G devices
    By bobogs in forum Computer
    Last Post: 18th Jul 2007, 03:24
