Salam and good Ramadan everyone
I have a strange problem with a video, in the first 15 minutes the audio is 3 seconds faster than the video, after that the audio is faster by 10 seconds and so one, is there any tool to resync audio without reencoding the whole video (I’ve did it with tempgenc but the isn’t multiple resyncking for it).
Here is the report.
Thanks in advanceCode:Format : Windows Media File size : 812 MiB Duration : 1h 29mn Overall bit rate mode : Variable Overall bit rate : 1 266 Kbps Maximum Overall bit rate : 3 086 Kbps Encoded date : UTC 2009-08-04 01:14:30.897 Video ID : 2 Format : WMV2 Codec ID : WMV2 Codec ID/Info : Windows Media Video 8 Description of the codec : Windows Media Video V8 Duration : 1h 29mn Bit rate mode : Variable Bit rate : 1 174 Kbps Width : 720 pixels Height : 526 pixels Display aspect ratio : 4/3 Frame rate : 25.000 fps Resolution : 24 bits Bits/(Pixel*Frame) : 0.124 Stream size : 753 MiB (93%) Language : French Audio ID : 1 Format : WMA2 Format profile : L1 Codec ID : 161 Codec ID/Info : Windows Media Audio 2 Description of the codec : Windows Media Audio 9.2 - 64 kbps, 44 kHz, stereo (A/V) 1-pass CBR Duration : 1h 29mn Bit rate mode : Constant Bit rate : 64.0 Kbps Channel(s) : 2 channels Sampling rate : 44.1 KHz Resolution : 16 bits Stream size : 41.1 MiB (5%) Language : French
115 "Did you think that We had created you in play (without any purpose), and that you would not be brought back to Us?"
Al-Mumenoon, Chapter #23, Verse #115
Did you make this wmv? If so what was the source and how did you do it?
Have you tried other media players to rule out playback issue possiblities? e.g. KMplayer, SMplayer, VLC ?
What you describe is usually caused by different audio/video lengths. An offset would have a constant delay like 3sec throughout the entire video.
Do a test: use asfbin to extract the audio & the video separately and play each to determine if the running time is the same. Mediainfo can be inaccurate, and reports it as the same. If this is the case, you would have to shrink/expand either the audio or video to match durations
The 2nd possibility is you have a wrong fps. (e.g. it should have been playing back at 29,97 or some other frame rate), I can't think of any tools that change the fps without re-encoding in wmv type files. (You can in other containers like .avi)
The 3d possibility is that you have a VFR (variable frame rate) wmv. Not much you can do short of re-encoding and using avisynth to make it CFR, with directshowsource, and convertfps=true. And that won't necessarily work.
Salam everyone
Well I've separated the audio/video the result is strange
but as expected (it is a downloaded video) :
audio : 01:29:42:00
video : 01:29:43:00
How can I sync this stuff since the video misses some frames from time to time.
Thanks in advance.115 "Did you think that We had created you in play (without any purpose), and that you would not be brought back to Us?"
If there are missing frames, damage or corruption, dropouts, that sort of thing - then it's next to impossible to fix. You would have to cut out the bad parts, and sync up each section with offest manually. Not worth the hassle.Originally Posted by abdelilah
Thanks to everyone for the help.
Multiple filter problem with ffmpeg - help please?
By Orinoco Womble in forum Video ConversionReplies: 6Last Post: 6th Sep 2011, 18:09 -
Merging/Converting Multiple M2TS files to MKV With Multiple Audio Tracks
By Nicholas S. Folsom in forum Video ConversionReplies: 1Last Post: 13th May 2011, 18:34 -
Deinterlace first or multiple times? Encoding source to multiple formats.
By greyfalcon in forum Video ConversionReplies: 1Last Post: 12th Apr 2011, 04:39 -
Batch hard encode multiple language srt to multiple videos
By clonius in forum SubtitleReplies: 4Last Post: 15th Jul 2010, 14:06 -
how do I join multiple avi files with multiple audio tracks?
By helloguys in forum EditingReplies: 1Last Post: 26th Dec 2007, 02:28
