I am currently using "Prism Video Converter" to convert about 4hrs worth of video in the mpeg2 format to .flv format
as i need to do this every other day.. is there a faster encoder out there? or is it just the hardware i use that matters?
maybe there exist a x64 encoder for .flv? dunno if that would make it any faster tho..
x264 will give you better quality, but slower
faster hardware will definitely make your conversions faster. If your application isn't multithreaded, you could run a few instances for example. Use taskmanager to check thread usage
not sure what encoder prism is using (ie. the actual back end engine, but I suspect it's ffmpeg)
You could try winff (uses ffmpeg), but not sure if it's faster than prism
hm.. It wont let me run more than one instance of prism..
Batch mux flv to mkv?
By Pitorasilo in forum Video ConversionReplies: 13Last Post: 14th Apr 2012, 04:25 -
Batch FLV to F4V - Keep File Structure of Source
By iSerce in forum Video ConversionReplies: 3Last Post: 23rd Jun 2011, 05:20 -
All-in-one Batch demux FLV -> mux mp4?
By gaikokujinkyofusho in forum Video ConversionReplies: 2Last Post: 19th Jan 2011, 23:34 -
which software works best for flv to dvd can i convert dvdor flv to divx
By rugrat23 in forum Video ConversionReplies: 2Last Post: 19th Jan 2011, 12:39 -
Which software do "DVDx" with batch encoding modes pls?
By amdk62 in forum Newbie / General discussionsReplies: 3Last Post: 23rd Jun 2007, 05:39
Statistics
Newest guides
Latest tool updates
New media comments
