VideoHelp.com Forum
Closed Thread
    Hi, i have some avi's (axxo) some have no audio on the ps3 ... even though the audio codec file is 0x0055 MPEG-1 Layer 3 which i think should play on the ps3... so i tried using avs to convert avi to avi .... i already have used this on a few avi that would not play on the 360 and it worked great... but not now, don't know if it's because there is a different problem or what, but after coversion the avi is well out of sync... i was using avs 5.6.1 so i updated and got the avs 6.3.1 and still it is way out of sync and plus with this newer version the output file has gone huge... from 700mb to over 2gb...
    i also tried winavi 8... alot of the time it crashes... but even with that the output file is alot bigger... anyone have any ideas i would like the files to stay near the same size...
    thanks
    mandy
    Buy/rent the movies instead of downloading axxo warez releases. Problem solved.
  1. AVS to psudo-AVI via VFAPI (1.05), in a BATCH FILE?
    By RogerTango in forum Video Conversion
    Last Post: 6th May 2012, 00:49
  2. Problem burning .avi file to dvd.. Burner tells me file is too big when not
    By accesskb in forum Newbie / General discussions
    Last Post: 6th Mar 2012, 18:28
  3. WinAVI output file size
    By Akusai in forum Video Conversion
    Last Post: 5th Oct 2009, 06:54
  4. I can't play a big avi file
    By Xp4nd3r in forum Newbie / General discussions
    Last Post: 20th Feb 2009, 06:29
  5. My AVI file ends up too big after edits!
    By enutz in forum Newbie / General discussions
    Last Post: 4th Jul 2007, 10:34
