VideoHelp.com Forum
    Is there anyway to back-up a 3D movie on a Blank 3D disc thats suports 3D format?
    The simple queation is, Where can I buy Blank 3D DVD discs
    Thanks.
  2. Hello Ladies stiltman's Avatar
    OK, jman98 I'm passing up a HUGE one here
    3D movies are put on Discs the same way as any other movie. They are also backed up the same exact way
    There are no 3D discs used
    Originally Posted by jagabo
  3. Member Noahtuck's Avatar
    I can sell ya some pretty cheap 8)
    Originally a member since 2001, LONG LIVE TARAN's!!!
    i have some 3d discs for sale, the problem is i lost my 3d glasses and these discs are invisible without the glasses, now, i can't find them.
    member since 1843
    You Da Man, stiltman! You are definitely Da Man!
    Sorry to everyone else. We'll keep the inside jokes to a minimum.
    Any disc is fine. Just use a good blank DVD. See the blank DVD media guides for information on what DVDs are the best to use for DVD-Video. See http://www.digitalfaq.com/reviews/dvd-media.htm
  7. Member Cornucopia's Avatar
    tealmarlin,
    what do you really want?
    If you're trying to back up a disc, state what the disc is (title and format/specs) and what equipment you've got.
    Only then can anybody begin to take you seriously. (You do realize that the companies that standardize DVD and BluRay haven't even finalized a true 3D standard, don't you?)
    thanks for all your advise,
  1. Blank Blu Ray Discs
    By anthonyfellows in forum Computer
    Last Post: 10th Dec 2010, 17:46
  2. Burner Won't Recognize Blank DVD-R Discs
    By ddowden1 in forum DVD & Blu-ray Writers
    Last Post: 23rd Aug 2009, 06:52
  3. Do 20GB Blank Discs Exists?
    By PHNeedsHelp in forum Authoring (DVD)
    Last Post: 23rd Apr 2008, 17:51
  4. which blank discs to use for recording
    By Lea Ann in forum Authoring (DVD)
    Last Post: 2nd Feb 2008, 22:46
  5. Toast 7 kicks out blank discs
    By Going gray in forum Mac
    Last Post: 22nd Aug 2007, 15:14
