Here is a tips for those having a Xamba 500. I have removed my HD 160Gb and then extended the IDE cable and pulled it out on the backside. On top of the desk I have mounted an cassette for IDE HD and then I can have more than one disk to swap.
very handy and easy done!
Right now I have a 250Gb disk and there were no problem to format the HD with the original function. It makes some more hours. If you have some old drives with lower cap. you can make use of them for the video. Have one HD for different kind of videos for example.
best regards
Bernt
[/b]
Results 1 to 1 of 1
JVC SR-DVM70 160GB part of the HDD image needed
By dvd4met in forum DVD & Blu-ray RecordersReplies: 1Last Post: 20th Aug 2010, 19:31 -
Toshiba HDD dvd Recorder RD-XS35SU 160GB HD
By sonny crocket in forum Newbie / General discussionsReplies: 2Last Post: 8th Sep 2009, 12:55 -
spare parts xamba 500
By berntlars in forum DVD & Blu-ray RecordersReplies: 0Last Post: 20th Aug 2009, 13:59 -
LG RH-7823 DVD Recorder (160GB HDD)
By Bud5 in forum DVD & Blu-ray RecordersReplies: 6Last Post: 21st Dec 2007, 01:15 -
What encoder chip is used in Philips DVDR3575H 160GB?
By Smells_Like_Feet in forum DVD & Blu-ray RecordersReplies: 1Last Post: 30th Aug 2007, 13:02
