VideoHelp.com Forum
    Hi all
    I try to stream a video with RTSP to my Android G1 Phone. If I send the stream with VLC to the Darwin Server and connect to the darwin server with the Phone, it works. But if I try to connect to the VLC directly with the phone, it doesn't work. As the environment (video file, server, network) is exactly the same in both tests, I am wondering what the difference is between VLC and Darwin? I mean, they both are RTSP-servers and send via the standardised Protocol RTSP.
    I have found another post about this (http://labtel.ing.uniroma1.it/opencdn/darwinp.html), telling that VLC sends a specific information different than Darwin. But I cannot believe that this small difference stops my phone.
    Any clue?
    Thanks for sharing you thoughts...Cheers[/url]
    vlc streaming can be very tricky. Maybe try an older version and see if it works any better(I have to use 0.8.6h to get decent rtp streaming). And be sure to visit http://forum.videolan.org/
    ANd I think this is more a streaming issue so moving you to our streaming forum
    Aha, okay. Well, then I have to try 0.8.6.
    Thanks for help
  1. Replies: 2
    Last Post: 19th Apr 2012, 16:25
  2. Need Windows streaming encoder for Quicktime/Darwin streaming server?
    By The village idiot in forum Video Streaming
    Last Post: 10th Feb 2012, 14:50
  3. Replies: 0
    Last Post: 31st Jan 2012, 09:23
  4. Replies: 7
    Last Post: 2nd Nov 2010, 11:00
  5. NVS365 video server streaming to VLC
    By derlyn in forum Video Streaming
    Last Post: 25th Sep 2009, 11:15
