When I encode VCD using 2300 kb/s and then play the CD in my DVD player, the time shown on it is doubled what it should be.
When I use VCDeasy and use the chapters option to build the bin file,
all the chapter times are also doubled what they should be.
Is this because the DVD player is going by the size of the mpg file?
I know that standard VCD is 1150 KB/s
When I use DVD2SVCD on a DVD and then play it on my DVD player, the timer setting is correct.
Is there a trick when I am using VCDeasy or TSCV that can show the time correctly on my DVD player?
Results 1 to 1 of 1
Which is the best video setting on DVD player?
By dzsoul in forum DVD & Blu-ray PlayersReplies: 3Last Post: 24th Dec 2009, 07:33 -
setting Sony DVP-NS78HS DVD Player region-free
By siluet in forum DVD & Blu-ray PlayersReplies: 1Last Post: 31st Oct 2008, 13:02 -
Tevion TDVD08 DVD Player - Picture problem when 5.1 ch setting used
By alfredspacey in forum DVD & Blu-ray PlayersReplies: 2Last Post: 1st Jun 2008, 01:03 -
Timer controlled DVD player?
By that Todd guy in forum DVD & Blu-ray PlayersReplies: 1Last Post: 7th Aug 2007, 12:16 -
How do you preset timer on DVD player/recorder LG RC6821W
By download in forum DVD & Blu-ray PlayersReplies: 3Last Post: 18th Jun 2007, 12:39
