VideoHelp.com Forum
    Hi
    Hopefully this is the right forum....just looking for a bit of help chaps!!
    I previously owned a Canon HV20, which I captured with P/Pro. Was all well and good, but had to sell for various reasons. I'm now in the market for a new HD camcorder, but cannot decide which recording format to get....
    I need an HD camcorder which can transfer to a non-firewire PC (thus ruling out HDV I think), so was looking into a flash camcorder (not keen on HDD cams). However, I need to create an SD DVD for a particular project which is playable in a standard DVD player.
    Therefore my query(s) is this: if I buy a AVCHD HD flash camcorder, and record the project in HD, can I transfer the AVCHD HD file to a SD DVD that will play in a normal DVD player? If so, which software would do the trick, and how straightforward would it be (bear in mind P/Pro and AE was too confusing for me!)? I'm aware you can reduce the resolution to SD, but would the AVCHD pose a problem?
    cheers
    D
  2. Member edDV's Avatar
    Originally Posted by shuffle2uk
    Hi
    cheers
    D
    Are your computer specs correct?
    2GHz, 4GB RAM?
    You can shoot SD h.264 with some models. Down conversion of HD AVCHD will be compute intensive.
    I suggest you obtain an AVCHD h.264 sample and then evaluate software starting with your P/Pro CS3 or CS4. Most would want to go the Cineform Neoscene digital intermediate route.
    http://www.cineform.com/neoscene/features.php
    http://www.kiva.org/about
    I can’t answer all of your questions but since I have used the Canon Vixia HF100 I’d highly recommend it. Just don’t buy a Samsung BD-p3600 to play back your AVCHD.
  4. Member Soopafresh's Avatar
    Intermediate codec as Ed suggested and/or a pretty fast computer.
    Vegas Movie Studio Platinum is pretty easy to edit with and cheap. http://www.sonycreativesoftware.com/...egasfamily.asp
    If you just want to convert the raw AVCHD files to DVD Mpeg2 you can use ConvertXtoDVD
    "Quality is cool, but don't forget... Content is King!"
  1. Bought a Sony AVCHD camcorder, now what?
    By gom in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 30th Dec 2011, 21:52
  2. New Camcorder - and AVCHD Editing.
    By blooda2 in forum Newbie / General discussions
    Last Post: 25th Nov 2011, 13:46
  3. software to batch convert m2ts format avchd to mts avchd?
    By masterpug in forum Video Conversion
    Last Post: 14th Aug 2010, 01:06
  4. Video Format query
    By ariesr in forum Software Playing
    Last Post: 14th May 2008, 08:07
  5. 8mm camcorder capture to dvd via EasyCap + Ulead - basic query
    By deaglan1 in forum Newbie / General discussions
    Last Post: 13th Dec 2007, 15:05
