Hi All,
I'm using Windows Movie Maker 2.1 on Windows XP SP 3. I'm inputting and also rendering to DV AVI Type 1. While I'm looking for something to replace Movie Maker with, there are a couple of in-process projects that were built with it. Ideally I'd like to slide them off the production line with the minimum of fuss with a magic trick I might learn from you.
The main problems I'm experiencing are:Please note that these aren't the usual video and audio sync loss issues. Sync is retained throughout. It's just that some clip boundaries are wrong, and the very last frame in a clip sometimes has its audio deleted.
- Sometimes, a clip's last frame before a clip join has no audio (this seems to occur more often when adding an overlay subtitle that starts on the next clip)
Sometimes a clip's first frame contains incorrect video, such as the last frame of the preceding clip, or sometimes even apparently out-of-sequence video
Sometimes these occur together
I've tried all the fiddles that have to do with WMM stability and performance, but no information on this problem has turned up.
Is there some magic trick I can try, like converting source to DV Type 2 before editing or something like that?
Many thanks,
Francois
Results 1 to 1 of 1
mencoder: seeking to frames (or cropping start frames)
By manchurian_candidate in forum LinuxReplies: 3Last Post: 13th Dec 2010, 08:53 -
Windows Movie Maker Will Not Start Timeline When Pressing Play
By kerrex_2006 in forum Software PlayingReplies: 0Last Post: 8th Apr 2010, 11:10 -
Dropped frames when importing Windows Movie Maker video into Magix edit pro
By gom in forum EditingReplies: 1Last Post: 27th Oct 2008, 10:55 -
Inserting blank frames with logos before movie start
By multiplex in forum Newbie / General discussionsReplies: 9Last Post: 1st Oct 2008, 20:30 -
Advancing/Rewinding Clip Frame by Frame on Windows Movie Maker (Vista)
By ione in forum EditingReplies: 20Last Post: 9th Sep 2008, 22:53
