VideoHelp.com Forum
Results 1 to 13 of 13
    I have a new TV Philips 42PFL8404H
    It is suposed to be able to play movies from a USB memory straight in to the TV.
    Format that is supported is: (some swedish text)
    USB-ingång (multimedia)
    USB-kontakten på din Philips 42PFL8404H LCD-TV ger dig åtkomst till JPEG-foton, MP3-musik och videofiler (MP3, LPCM, WMA v2 upp till v9.2, JPEG-stillbilder, MPEG1, MPEG2, MPEG4, AVI (DivX, DIV5, DX50, DXMF), H.264/MPEG-4 AVC, MPEG-Program Stream PAL, WMV9/VC1).
    But when I watch 2 seperated movies on it, one is lagging a lot so that I cant watch it and the other is just fine.
    Mediainfo on working on is:
    General
    Complete name : F:\Movie1. XviD..avi
    Format : AVI
    File size : 702 MiB
    Duration : 1h 35mn
    Overall bit rate : 1 033 Kbps
    Writing application : FairUse Wizard
    Writing library : The best and REALLY easy backup tool
    Video
    Format : MPEG-4 Visual
    Format profile : AdvancedSimple@L5
    Format settings, BVOP : Yes
    Format settings, QPel : No
    Format settings, GMC : No warppoints
    Format settings, Matrix : Default (MPEG)
    Muxing mode : Packed bitstream
    Codec ID : XVID
    Codec ID/Hint : XviD
    Duration : 1h 35mn
    Bit rate : 896 Kbps
    Width : 608 pixels
    Height : 336 pixels
    Display aspect ratio : 16:9
    Frame rate : 23.976 fps
    Resolution : 24 bits
    Colorimetry : 4:2:0
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.183
    Stream size : 609 MiB (87%)
    Writing library : XviD 1.2.0.dev47 (UTC 2006-11-01)
    Audio
    Format : MPEG Audio
    Format version : Version 1
    Format profile : Layer 3
    Codec ID : 55
    Codec ID/Hint : MP3
    Duration : 1h 35mn
    Bit rate mode : Constant
    Bit rate : 128 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Resolution : 16 bits
    Stream size : 87.0 MiB (12%)
    Alignment : Aligned on interleaves
    Interleave, duration : 42 ms (1.00 video frame)
    Interleave, preload duration : 504 ms
    Writing library : LAME3.97
    Encoding settings : -m j -V 4 -q 2 -lowpass 17 -b 128
    And the one lagging is:
    General
    Complete name : C:\Videos\Movie2.xvid-amiable.cd1.avi
    Format : AVI
    File size : 699 MiB
    Duration : 1h 2mn
    Overall bit rate : 1 561 Kbps
    Writing application : VirtualDubMod 1.5.10.2 (build 2540/release)
    Writing library : VirtualDubMod build 2540/release
    Video
    Format settings, Matrix : Default (H.263)
    Codec ID : XVID
    Duration : 1h 2mn
    Bit rate : 1 103 Kbps
    Width : 640 pixels
    Height : 272 pixels
    Display aspect ratio : 2.35:1
    Colorimetry : 4:2:0
    Bits/(Pixel*Frame) : 0.264
    Stream size : 494 MiB (71%)
    Writing library : XviD 1.2.1 (UTC 2008-12-04)
    Audio
    Format : AC-3
    Format/Info : Audio Coding 3
    Codec ID : 2000
    Duration : 1h 2mn
    Bit rate : 448 Kbps
    Channel(s) : 6 channels
    Channel positions : Front: L C R, Surround: L R, LFE
    Stream size : 201 MiB (29%)
    Alignment : Split accross interleaves
    Interleave, preload duration : 500 ms
    Can it be that its the audio (AC-3) that is messing with the TV so it is lagging or something else?
    Would be happy if I could get it sorted out.
    Thx in advance
    I would say that is a fair assumption. AC3 is not listed as a supported format for the multi-media playback functions of the set.
    A simple test. Load the video into virtualdub. Set video to direct stream copy, and audio to full processing. Select MP3 as the audio codec and configure it for 192 kbps CBR. Save a new file and test play this file. If it works without lag, AC3 is the most likely cause.
    Read my blogs here and here. Change England's Libel Laws - Sign Here
    Personally, I think playback directly on the TV via USB is crap. If the TV can't even keep up with AC3, then that "feature" is useless.
    I wish the manufacturers had never seen fit to offer this "feature" as it's completely useless except to cheap people who don't want to buy proper players for playback. It's not like Burner72 is powerless. HDTVs were sold for years without the capability, yet we all somehow found a reason to keep on living and just simply bought DVD and media players that worked for our needs without worrying about using the TV directly for the job.
    How do I do that? When I select MP3 under Audio it open a window and want me to select a file????
  5. Always Watching guns1inger's Avatar
    Audio -> Full Processing
    Audio -> Compression
    Select your MP3 codec (usually LAME MP3) and configure it
    Video -> Direct Stream Copy
    File -> Save as AVI (Here you will have to select a new file name because you have to create a new video with the new audio track)
    Noob question, but how do I install the LAME codec?
    I unpacked it in the same folder were I have vdub, but when I run vdub I still dont have a MP3 when selecting audio compression.
    Thx for bearing with me
    Right click on the INF file and select Install.
    You need to right click on the file LameACM.inf and select Install.
    Dont know what Im doing wrong.
    I rightclick and select install.
    But whats happening is that a small window flashes for 0.5 seconds on the upper left corner of my screen and the icons in the screen flickers a bit.
    When I start vdub again I still dont have the mp3 choise.
    Can it be Vista screwing with me or am I totally clueless
    Are you using vista x64?
    If so, read DarrellS' reply
    http://forum.videohelp.com/topic364494.html
    yupp Vista x64 here
    will try it out
    Looks like Im a hopeless case as when I typed the comandline in darrellS reply Im missing the "HinfSection" on my computer so it looks like Im stuck so that I cant install and codecs on this computer
    If all you want to do is test whether AC3 is the problem just disable the audio track in VirtualDub. Create an AVI with just video. See it that plays on your TV.
    Audio -> No Audio
    File -> Save as AVI
    If it turns out that AC3 is the problem you can try using AviDemux to convert the AC3 to MP3. It uses its own built in codecs so you don't have to install Lame ACM.
  1. Replies: 23
    Last Post: 13th Oct 2009, 21:33
  2. Record straight to DivX/Xvid ?
    By joecass in forum Newbie / General discussions
    Last Post: 17th Sep 2009, 11:58
  3. Replies: 0
    Last Post: 11th Jan 2009, 19:47
  4. Replies: 9
    Last Post: 8th Sep 2008, 10:31
  5. Replies: 2
    Last Post: 13th May 2008, 01:18
