Hello! I have DVD Player Toshiba SD-790.I would like to change them to region free.Please, anyone who knows the codes or FW may help.
Many thanks!
Results 1 to 11 of 11
Thread: Region code for Toshiba SD-790
There is no hack for that player.
Thank you! And how can I do it officially? Is there any licensed firmware, and codes and where can I get it?
Ty ne ponimaesh. U proigrivatela net "hack".
English translation - You don't understand. The player doesn't have a hack.
Have you tried DVD's in the machine that aren't your Region?
I'm asking because the Toshiba SD-790 is often sold already Region Free.
KBeee!I've tried DVD's Region 0, it doesn't work. DVD's Toshiba SD-790 Region 5 only sold in Russia!
jman98 spasibo (thank's)! What can I do in my case? Is there any alternative? Can I use the following options for my DVD player?
http://www.videohelp.com/dvdhacks/toshiba-sd490/10175
http://www.videohelp.com/dvdhacks/toshiba-sd680ky/8783
Because your player is a different model, those options probably will not be successful. I looked at them and I don't think your player will be damaged if you try. Probably all that will happen is that the codes will do nothing.Originally Posted by smallbear
Wow! That's a harsh lock-down. No wonder you need a region free code if the machine won't even play an All Regions 0 DVD!Originally Posted by smallbear
Depending of the case, if you cant' find any firmware to "unlock" your machine, you'll need to use anydvd or similar ones applications to make "free" region your disc.
After that, you can copy these dvd's to your PC, entirely and burn it into a blank media dvd disc ( 4,5gb or 9 gb - these one avoiding any loss quality).
Doing that way, you can watch the movie in your dvd player without problem.
best regards.
looking for the region free code for a toshiba combo SDV 398
By julax in forum DVD & Blu-ray PlayersReplies: 2Last Post: 19th Jan 2010, 01:32 -
Change region code, how? Toshiba portable DVD player (SD-P1400) 2004 model
By Traxx29 in forum Portable VideoReplies: 0Last Post: 27th Dec 2009, 18:42 -
how to change DVD player region code on Toshiba SDk 730
By sashatheman in forum DVD & Blu-ray PlayersReplies: 1Last Post: 12th Dec 2009, 06:17 -
toshiba sdk 990 region free code
By moll0 in forum DVD & Blu-ray PlayersReplies: 3Last Post: 4th Sep 2009, 02:08 -
need region free code for toshiba TDP-ET20
By synapse69 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 27th Nov 2007, 10:09
