VideoHelp.com Forum
    Hi,
    I'm getting sick of VD. I have ffdshow installed and use that to encode and after I spent 3 hours trying to get VD to recognize an .mp4 file unsucessfully, I decided it may be time to use another application. Does avidemux use ffdshow? what other applications use ffdshow? Can I use ffdshow alone to encode videos? I love the configuration (VFW??) possibilities in ffdshow and want to continue to use that with any file I encounter.
    thanks
    avidemux does not use ffdshow.
    You could use avisynth to decode the mp4 and then open in it virtualdub.
    thanks, it worked. but when i did direct stream copy for only a portion of the video, it was HUGE!!! why is that??
    Because avisynth outputs uncompressed video, so a direct stream copy through virtualdub produces an uncompressed file. Try using Fast recompress instead, and make sure you select a codec and configure it before saving.
    Read my blogs here and here. Change England's Libel Laws - Sign Here
    that explains it. I'll compress it and try again.
    One thing I did notice however, was after when I tried a video that didn't require avisynth (an mpeg video) I checked the vid bit rate and it was 1500 (original video). I then compressed it as I normally do at a vid bit rate slightly higher than the original and the file was 3x the size of the original. Did the installation of avisynth keep the video from getting compressed correctly hence the large file size?
  6. Always Watching guns1inger's Avatar
    Nope. You must have missed something else in your settings. Was Audio set to direct stream copy ? If not, it will have been output as LPCM uncompressed audio, which uses a fair whack of space. Use mediainfo to confirm
    You're right. I'm sure avisynth has nothing to do with it, but no matter how I encode it, it always comes out about 3x larger than the original. I feel I am hijacking my own post and somebody may also need this info so I will post separately.
    btw, i've downloaded mediainfo 2x and can't figure how to use it. There's no application except for the uninstall!
    If you right click a video, the option should appear in the context menu
    Or you can open mediainfo from the start menu, then use file=>open
    I already explained reasons why not to use ffdshow as an encoder in your other thread
    You can get some penicillin from you doctor
    Sorry just a joke
  1. BD-RE and ffdshow
    By ttheb1 in forum Blu-ray Ripping
    Last Post: 29th Jan 2011, 23:10
  2. wma3/9 not in ffdshow?
    By rjc7394 in forum Audio
    Last Post: 15th Sep 2010, 13:50
  3. What is FFDshow?
    By terrypin in forum DVD Ripping
    Last Post: 7th Apr 2010, 17:26
  4. What is ffdshow and should I be using it?
    By Hank Kinsley in forum Newbie / General discussions
    Last Post: 27th Jul 2007, 00:52
